![]() | Home > Puma (Tdci) > 2008 2.4 tdci Radical loss of power |
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4341
I believe it will run with the MAF disconnected. 2007 110 TDCi Station Wagon XS
| Landymad90 Member Since: 19 Nov 2020 Location: South Coast Posts: 4
Thank you Bluest will try that one first.
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
I don't know what you mean by "fuel vapor temperature Sensor" but if it isn't the Volume Control Valve then I'd certainly change the VCV.
Thanks blackwolf. I had seen on another post you had suggested this to someone else who has similar problems. The part I changed is LR009837 see pic, is that it? It fits into the back of the fuel pump.
Thank you! Click image to enlarge |
| Johan H Member Since: 12 Oct 2017 Location: Helsingfors Posts: 36
I might be totally off here, but I had a similar problem and it turned out the vanes inside the turbo were sticking, try moving the actuator rod on the side of the turbo. You can undo the c-washer and move it all the way. Sometimes it moves freely when cold and sticks when hot.
When I had this problem I just moved the rod back and forth, sprayed WD40 all over it until it started moving freely again. |
Thanks Johan I will take a look at that!
Yes, that's the thing. It actually controls the flow of fuel from the LP side of the fuel pump to the HP side (hence the name, Volume Control Valve), and by so doing is how the common rail pressure is regulated. It is a very fragile component and is usually destroyed by dirt or water in the fuel. |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
And if the VCV fitting goes anything like mine it’ll be fine and straight foreword and won’t need any programming either after. I would however disconnect the battery when you change it though.
(General safety procedure). Mine came from PF Jones, couldn’t fault it running like a dream now. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
