![]() | Home > Maintenance & Modifications > Whitbread Offroad Roll Cage.....anyone used or bought one? |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
Hello all,
Just looking at a roll cage for the DC. I've come across Whitbread Off-road in my travels. Has anyone used them? Ordered or have one of their roll cages? Quite a price difference to Safety Devices (£500) and as I am not getting an internal version nor does it need to be FIA competition spec, I'm happy to look further afield. They seem to be used some Mountain Rescue teams, and in some form of competition, so I'm presuming at face value that the cages do the job. Any thoughts? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
I've owned one (and SD and P&P cages).
A mate had a Whitbread cage fitted and managed to use it the very next day. ![]() Click image to enlarge |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3401 ![]() ![]() |
SD were doing a deal on fitting when I bought mine so got it fitted at their factory
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 687 ![]() ![]() |
Snap. We had ours done by the factory too. Great guy fitted it can't remember his name now, superb experience at the time.
My only issue is it seems they've forgotten to do up one of the nuts which attaches the front of the cage to the chassis outrigger, which was a disappointment - i've only just found it whilst in there fitting my FBH, and know it wasn't done up from new because it's a nyloc thats only just into the nylon retainer bit and nowhere near any clamp point. Have a look round yours I'd suggest just in case. ![]() Click image to enlarge ![]() Click image to enlarge |
chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 412 ![]() ![]() ![]() |
Likewise i have a SD external cage and it has been brill. 20 years old. Been re powder coated once when the chassis was changed and has stopped the top peeling off with the roof tent when we rattled about in the Sahara.
It is now home to a bit of a pneumatic mast which it handles with no complaints. ![]() Click image to enlarge |
I love that chopcat, i looked on your website the other day... after looking at KE5EE’s array
Now that might prove a bit of a challenge even for the defender. I could see it lying on its site after a strong gust of wind !
Mine is a North Off-road.
![]() Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1241 ![]() ![]() ![]() |
I've been up to their workshops to collect some bits for a mate (they're reasonably local to me) and they've certainly got the skills there.
I'm not a fan of how far out they normally sit. As they're just a small company (family and a few mates) it's worth bearing in mind they can customise pretty much anything so might be worth bearing in mind. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Thanking you all. SD have always been first choice for rep/build etc, also look (as pointed out on above, offering the lowest profiles). But looking into it a bit more and actually I might have to weld and spray the cage from Whitbread as well. Wipes out any 500 quid saving as I’d have to send myself on a welding course and then rent the kit.
![]() But safety is what matters most, so thanks again for reinforcing that SD is the way to go. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Don't rent, buy. And the welding would be an investment
![]() Years ago bought myself a MIG, then ended up with a TIG and recently had a friend (used to be a gas pipe welder among other things) show me how to stick. You'll quickly save the money back on the welder. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8271 ![]() ![]() ![]() |
very good cages, well respected Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
North delivered good quality but then as I ordered a flat pack I had to weld it myself. So the quality is now more depending on me then on north.
![]() Next to hitting some trees and other item in my way the best test is pictured below: ![]() Click image to enlarge I got stuck here and broke my winch cable. Then we tried to pull with 2 winches. No luck. After that we found that a tree truck was stuck before the chassis crossmember so just after this picture my 90 was pulled over and winched out easily. The cages did move at all It kept the same distances to the roof gutter so I am happy. My case is not completely standard. I have a cross in the middle hoop and the front part is bolted to the middle hoop so I can remove it easier when needed. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
I chose Whitbread as the Army use them and I thought you couldn't get a better recommendation than that. Been off once when I had a respray, painted now with Raptor. Have used it to winch myself out sideways. They also fitted a bull-bar which has saved many a impact down a lane. Peter
Cage off and un-painted: ![]() Click image to enlarge Front bull bar: ![]() Click image to enlarge Full external cage bolted to chassis: ![]() Click image to enlarge |
