Home > Puma (Tdci) > Puma cuts of in 6th gear uphill !
Page 4 of 5 <12345>
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Mine also started doing this about 2 years ago.
I changed the coolant and fitted the spacer.
Tried it over the summer and it was ok but very close to the 110degrees that sets it in to limp mode, so next year I'll get the thermostat changed and it should be fine.
I read somewhere that land rover recommends towing in 5th and the temperature doesn't rise if in 5th gear, maybe it has to do with overfuelling. but if you add the spacer and the thermostat it should solve it.
Fabio
Post #870850 2nd Dec 2020 7:25am
Bluest
Maybe the fan needs a smaller pulley to speed it up. That would give the same effect as running in a lower gear. When I had this problem in the Spanish heatwave last year, I found that running in a lower gear and keeping the revs high helped. 2007 110 TDCi Station Wagon XS
Post #870854 2nd Dec 2020 9:15am
Fabio
In this Country I’ve never had an issue,
Only when driving in Spain, Portugal or Italy.
Here it doesn’t get hot enough, unless you are towing and I don’t tow anything heavy.
Fabio
Post #870873 2nd Dec 2020 11:13am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
If you haven’t done the thermostat mod that’s first port of call 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #871015 2nd Dec 2020 10:20pm
Alex von Staffeldt
Denmark 2008 Defender 110 Puma 2.4 SW Alpine White
Just changed the waterpump, CHT sensor, fan spacer, thermostat & radiator. Took her for a ride and now there is no heat when gearing down or when idle !
Anyone has had the same problem.
Now im going for a longer ride to see if it cuts of in 6th gear.. FINGERS CROSSED. Defender 110 Puma 2.4 tdci
Post #871097 3rd Dec 2020 12:43pm
Greyman110
Hope it goes well!
Fingers crossed!
Post #871099 3rd Dec 2020 12:45pm
Eduardo
Same problem here for a loooong time.
As described
6th gear
120 KPH
mild long slope up
hot days (>35C)
After certain time, temperature increase to 112-115C and the engines going to limp mode.
Cylinder compression is normal and no coolant consumption
I have already changed the thermostat, I have the fan spacer, a new enhanced radiator and intercooler and the temperature has been drop compared to the initial situation, but still happens. I have a preset alarm in my ODCBII reader when the temperature going over 110C to avoid the trouble reducing speed to 100 KPH when all bach to normal 90-95C
Cheers! Eduardo
Post #871100 3rd Dec 2020 12:57pm
Alex von Staffeldt
UPDATE !!
Hello Guys...
Just went for a 100 km ride with various driving.
Up hill in 130 kmt and nothing happend. Some times as much as 140 kmt !!!
Is has certainly worked for the Lady.
Putted in 300 kg of sandbags in the back of the landy to simulate towing.
I am so happy for the difference. Defender 110 Puma 2.4 tdci
Post #871147 3rd Dec 2020 5:08pm
Greyman110
That’s good news!
I’ll change my rad, thermostat and CHT and see if that fixes my issue.
Post #871157 3rd Dec 2020 6:05pm
Alex von Staffeldt
I hope that it will keep like this, and that it fixes your issue as well.
Il keep my fingers crossed. Defender 110 Puma 2.4 tdci
Post #871158 3rd Dec 2020 6:06pm
Alex von Staffeldt
Greyman110 wrote:
That’s good news!
Took a long drive from Jutland to Sweden yesterday. Normally she cuts of when going 100 kmh..
Now i can drive 110-120 without cutting off.
I had one incident when i was driving up hill for 3 km. I wanted to overtake another car driving 100kmh and when i reached 125kmh she cut out.
Thats totaly fine with me. Normally i drive 100-105 kmh and now she dosent cut out at that speed.
The conclusion is that it has really helped and no i just enjoy that i can overtake cars driving 90 on the motorway without cutting out. Defender 110 Puma 2.4 tdci
Post #871438 5th Dec 2020 3:36pm
Greyman110
Thanks for the update!
Thats positive!
I have now ordered the rad, thermostat and CHT so will hopefully fit next week.
I did change my VCV today which I think has made it sound better and it certainly feels smoother than before. I don't think it's fixed my issue but I'll do a run tomorrow just to check.
Do you happen to have live stats? If you do it would be interesting to hear what temp yours now sits at when cruising.
Post #871480 5th Dec 2020 9:14pm
Alex von Staffeldt
Hi Greyman110.
Sorry i dont have live stats.
I think i will change my VCV as well.
Maybe with a little luck it will make mine sound better also Wink Defender 110 Puma 2.4 tdci
Post #871517 6th Dec 2020 4:00am
Alex von Staffeldt
[quote="Greyman110"]Thanks for the update!
Took a ride out hunting today. No heating in the cabin AT ALL !!
Have you experienced that ? Defender 110 Puma 2.4 tdci
Post #871794 7th Dec 2020 3:01pm
Greyman110
I had it blowing hot and cold.
First check the coolant level on cold. Next check the white plastic heater valve at the back of the engine after the car has warmed up to make sure coolant is getting up to it.
I made my heating better by starting the engine and doing a bleed. I then drove it to get it up to temp and I bled it again through the bleed screw with the engine on.
WARNING - When you do this boiling coolant can spray everywhere! I cut the the top off a water bottle and put a notch in the side so it would go over the pipes. I then used the bottle top opening to put a screw driver in to undo the bleed screw.
I used the bottom half of the bottle to catch run-off so I could also inspect it.
* If you had a garage fit do the recent work, they would have had to empty the cooling system. They should have refilled it and then followed the recommended landrover instructions.
Post #871796 7th Dec 2020 3:24pm
Page 4 of 5 <12345>
