![]() | Home > Puma (Tdci) > Yuasa HSB020 will it fit |
Moz Member Since: 29 Jan 2020 Location: Cumbria Posts: 25 ![]() ![]() |
Yuasa HSB020 will this shoe horn in 🤔 oh its a puma 2.4 as the old one is on its way out
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20937 ![]() ![]() |
This one fits:
https://www.ebay.co.uk/itm/122851172675 This is the one I have fitted and is an upgrade on factory fit. Very pleased with it. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2065 ![]() ![]() |
....and it’s a bit cheaper here:
https://www.tayna.co.uk/car-batteries/yuasa/ybx5019/ |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 945 ![]() ![]() ![]() |
Brilliant information guys. I’m needing a replacement too
Nice find Daz, I’ve had it in a year now. Turns over great from stone cold.
Fits straight in, factory retainer clamps fit. Battery post clamps fit and breather tube connects up perfectly. You can indeed tell it’s got that bit more power than my old one did. The old one lasted at least ten years. It has a battery state indicator too to show you when it needs replacing. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I’ve got the same battery Steve.
![]() Fitted mine about a month ago. |
kyvlle Member Since: 22 Jul 2016 Location: Essex Posts: 73 ![]() ![]() ![]() |
+1 for the Yuasa 019 battery (I use it in my Td5)!
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
Another for the Yuasa 5019 here.
Thanks chaps I was originally looking at the YBX5019 but just wondered if anyone had got the slightly bigger one in handy that they come with the 5 year guarantee as well whats it like dealing with tayna and warranty if it go's tits up ?lol my original has lasted 11 years so far just the short journeys to work in the dark then home in the dark are not helping the old girl
I got my new Yuasa (on my 2014 van) to replace the original earlier this year as I found I needed to keep re-charging it. It's a bit higher CCA (900 vs 800) than the original.
But having charged up the original one again after I fitted the Yuasa, it seemed okay, so it's now installed on our narrow boat as the engine battery, and working fine! Maybe it was lack of use (only short journeys), coupled with the alarm draining it constantly, that made it seem as though it was failing. |
Not to put a downer on the Yuasa YBX5019, I use it personally myself. The first one died just after 3 years, and Halfords replaced it under warranty with no fuss. Probably down to my usage pattern of mostly short trips.
Think you might be right Joe lock down+short trips +starting+lights+blowers+subwoofer+alarm has taken its toll lol charged up fine and has been ok so far but put an order in for a new YBX5019 as she's about due a new one after 11 years hope the new one will do as well lol
If you use LED lights then you won’t have as much current draw. Saves the battery and fuel.
That’s the perfect reasoning to upgrade to your financial advisors aka Wives. ![]() ![]() I think most of us still put the heated seats on though. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
