Home > Puma (Tdci) > Timing Chain replacement - with or without sprockets
Page 2 of 2 <12
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
I'm looking to do mine too, unfortunately the VKML84006 is out of stock everywhere i've looked Sad
Post #869827 27th Nov 2020 12:26am
Dinnu
Julie wrote:
SKF is most probably original supplier
German gearbox, German injection (the 2.2) and perhaps à German timing chain, too Whistle
I would not be surprised if it is designed in Germany, manufactured in China. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #869855 27th Nov 2020 8:58am
ickle
Resurrecting an old thread, is there a decent write up anywhere of the correct procedure for the cam chain swap - its on the to do list...
Cheers Keith
Post #909587 26th Jun 2021 8:15pm
Dinnu
Excellent video by Nigel Thumbs Up
Post #909692 27th Jun 2021 8:17pm
ickle
Thanks Dinnu,
I'll run through that in the next couple of days.
Much appreciated.
Keith
Post #909870 28th Jun 2021 9:02pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Dinnu wrote:
Oldowner gave me an idea.. I searched on onlinecarpart.co.uk but under transit, and found more options, including and SKF part. Not sure on SKF chain quality, I know they make good bearings. And it is cheaper than FAI.
I also found the Ford part number.. will check with local Ford agent.
**************** IMPORTANT EDIT ***********************
From SKF site, https://www.vsm.skf.com/mt/en/products/VKML84006
VKML84006 is the correct one for LandRover, not the partnumber in the embedded image. Price is £100 more because owning a Defender means you can afford spending £100 more than the white van man.
Just want to let folk know when the garage tried fitting this kit to my 2.2 2012 the sprocket for the fuel pump did not match the original so they had to order that separately.
Post #970668 10th Nov 2022 7:32pm
Page 2 of 2 <12
