Home > Maintenance & Modifications > HD Drive Member paint problem
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
I’ve spent some time this last couple of days preparing a pair of shiny new HD drive members. Two coats of etch primer, then several coats of Simoniz tough smooth black spray. All was great till I went to fit them tonight.
Following other threads I’ve read on the subject I used zinc plated cap screws and matching spring washers and as soon as I nipped them up (before I even got Torque wrench out) the paint stripped around the screws...what have I missed? The picture shows the flange I tried to fit this evening above the other, which I haven’t!
Post #869821 26th Nov 2020 11:40pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
The primer/paint hasn't bonded to the metal.
Even with an etch primer, you will struggle to get a paint to withstand the pressure of mechanically fixing something to it without proper curation times and a lot of luck.
Post #869824 27th Nov 2020 12:13am
Likeomg
mount them and mask up and spray over the bolts ?
Post #869825 27th Nov 2020 12:18am
MussEd
I left the primer for over the recommended 24 hours. Guess I’ll need to try again...And hope for more luck!
Post #869829 27th Nov 2020 12:32am
MussEd
It might come to that...
Post #869830 27th Nov 2020 12:32am
bankz5152
I used Buzzwelds GIO. Let them sit for 24 hours
Paint still there when I did the nuts up
Post #869841 27th Nov 2020 7:03am
I know that you've followed the process that I described when I did mine. I can only think it's either the paint itself or perhaps the temperature, as I did mine in the summer Confused Darren
Post #869842 27th Nov 2020 7:17am
SteveG
2005 Defender 90 Td5 CSW Belize Green
Did you scotchbrite and fully degrease the surface before etch priming?
I have no idea how good the primer and Simoniz paint you’re using are, but you’d also ideally need to leave them for 7-10 days to fully harden before fitting.
Or buy the black HD ones from Bearmach 😉😉😉
Post #869843 27th Nov 2020 7:21am
LR90XS2011
did you use a spring washer, cap heads or bolts?
remember the paint will affect the mechanical torque, the best approach is to clean off or mask where the bolt head or washer will meet the drive member, if spraying just place washers where the bolt heads will be when fitted. effectively masking the fixing area DEFENDER 90 TDCI XS,
Post #869847 27th Nov 2020 7:46am
MussEd
Spring washers with cap head screws.
LRA - The temperature may play a part I guess. Think I’ll sand it all off, etch prime again and leave till I’m back at work Tuesday and can apply paint indoors in warmer atmosphere. Just done loads of work in the house, indoor spraying would NOT be appreciated!
LR90XS -
Great tip! Will do this too...thanks for the advice guys.
Post #869885 27th Nov 2020 11:04am
The appearance in the photos suggests that the surface was not adequately degreased before paint, and as a result the etch primer hasn't etched and and the paint hasn't adhered.
There shouldn't be any particular problem painting a yellow passivated finish, one of the benefits of the passivation process is that it can help with paint adhesion provided that a suitable paint system is used.
I would be looking closely at the preparation processes.
Post #869892 27th Nov 2020 11:20am
Balvaig
If you can get away with it - i put small items after prep and painting and leaving for 24 hours nto the domestic oven at 50 -60 for an hour.
Cures the paint a treat.
SWMBO is usually out during this period, but wonders about the odd smell when she gets back. Whistle
Post #869901 27th Nov 2020 11:58am
^^ It's not just me who does this then! Rolling with laughter
Post #869915 27th Nov 2020 1:43pm
MussEd
Given I’m the chief cook and bottle washer when I’m not at work I’d probably get away with that!
Post #870093 28th Nov 2020 2:05pm
MussEd
Finally got my new flanges painted properly and fitted today. Thanks for all the help and advice.
Post #872942 14th Dec 2020 9:15pm
