Home > In Car Electronics > Improving DAB reception
excossack
Currently have a DAB antenna stuck to the alpine glass and in the main, reception is OK. I do get patches where the signal just goes to crap and then reappears later on. Always in the same built up area.
Is this normal for DAB to crap out in certain areas. ?
I think the only option is an external DAB antenna ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #869163 23rd Nov 2020 5:28pm
Yes, it’s fairly common whatever aerial set up you have. It’s more due to patchy signal areas rather than pick up of signal of your system.
I still tend to find FM signals are more reliable and less likely to drop off than DAB. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #869193 23rd Nov 2020 7:29pm
DAZ110
The DAB on my radio is connected to the original Land Rover aerial with a DAB aerial splitter and generally the signal isn’t to bad, but still have drop outs here and there.
Post #869228 23rd Nov 2020 9:52pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I use a Digital aerial splitter same as DAZ110, it’s not too bad does drop out occasionally but we have plenty of hills in Derbyshire!
I found if I go towards Notts/Lincolnshire it hardly ever drops out.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #869389 24th Nov 2020 7:19pm
Andy T
United Kingdom 2011 Defender 110 Puma 2.4 SW Fuji White
I tried a splitter but got fed up and have now switched to a DAB aerial (oddly flexible in the breeze Rolling with laughter ).
TBH although it's better it still has drop-outs in the Chiltern Hills.
I agree with above comments about the issue being the DAB signal Crying or Very sad rather than ability to capture it 2011 2.4 White 110 CSW LHD
1998 300TDi Wolf TUM
2015 2.2 Corris Grey 90
2009 2.4 Alaska White 110 Commercial - gone
2006 TD5 Barolo Black 90 - gone
1995 TD5 Green 90 - gone
1984 2.25 Marine Blue 88
Post #869535 25th Nov 2020 1:39pm
excossack
Which DAB aerial did you go for? 1999 Defender TD5 110
Regards
John M0VAZ
Post #869543 25th Nov 2020 2:59pm
Andy T
https://www.calearo.com/en/products/dab-dab-antennas
Post #869738 26th Nov 2020 5:11pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
And I clicked onto this thread hoping to find a solution to the eternal problem!
I can´t offer a better solution, but only share the annoyance at how inconsistent DAB reception is. Sometimes brilliant, but often on the move, that annoying blackout two second followed by a repeat of what went before. Like listeening to a stuttering newsreader. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT�s,
Recaro CS�s, anorak, wellingtons
Post #869751 26th Nov 2020 6:24pm
excossack
Cheers Andy T 1999 Defender TD5 110
Regards
John M0VAZ
Post #869868 27th Nov 2020 9:49am
AMBxx
DAB is the radio equivalent of those horrid CFD light bulbs. Even now, it's more reliable to stream a radio station from your mobile phone using your mobile data. Only reason it isn't more widely used is the cost of data, but that's rapidly dropping.
Post #869895 27th Nov 2020 11:41am
