Home > Puma (Tdci) > 2.4tdci ‘08 lumpy idle
cypermethrin
United Kingdom 2008 Defender 110 Puma 2.4 SW Bronze Green
So having sold the 90 300TDi a year ago - and after significant nagging we now have a ‘08 2.4 110 SW with 56k miles
We bought it privately and it is surprisingly refinement cf 300TDi
One thing we did notice that it surges at idle - most notably once warm
Reading a few threads on here the likely suspects are
Blocked EGR valve
Vacuum Control Value
The MIL hasn’t come on which I presume it would do if it was the EGR? I will try and get the codes read...
Glad to back -
Post #868993 22nd Nov 2020 5:49pm
The VCV - volume control valve rather than vacuum - is a very likely suspect. Darren
Post #869001 22nd Nov 2020 6:08pm
cypermethrin
Thanks for the replies and counsel
New VCV ordered from PF Jones and fitted by my 17 y.o. son over the weekend - he said it was quite straight forward having small hands clearly helps! Started on the 2nd attempt.
Also did the pump and VCV learn using Forscan s/w and 17 quid ELM327 USB thing...no DTCs recorded either... needs a good run to ensure its all sorted - that's tomorrow !
Post #870464 30th Nov 2020 12:41pm
You could have just fitted it as it was with no programming. I did and everything was all good with it and self learns.
I used the same supplier and has been running really nice ever since - couldn’t fault them.
If you get it again think about replacing the MAP & MAF Sensors. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #870583 30th Nov 2020 7:48pm
