![]() | Home > Puma (Tdci) > Puma engine oil sump pan |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
1) Yes.
2) With one of these, or something similar: https://www.lasertools.co.uk/product/5026 3) Probably, but bearing in mind that the genuine ones are not great perhaps not as bad an idea as at fist it might appear. 4) The very early 2.4s had a sump which would get walloped and ruptured by the front propshaft on full axle deflection. I can't remember when the sump changed, but I think it was about 2009 and I would be astounded if the aftermarket ones were the original defective design. Make sure you get a Landrover sump not a Transit sump, of course. |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
I chose a genuine one for mine, I didn’t do it myself but it’s been fine since and the last one lasted ten years.
It began to leak from the seal on mine. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4341
Cheers chaps, most helpful. Not seen one of those little gadgets for separating the gasket before
Is there anything else I need for this job, apart from liquid gasket? I assume the bolts can be re-used. 2007 110 TDCi Station Wagon XS
I had the fixings replaced, but I don’t doubt you can re-use them.
| Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 247
My 2.2 puma pan rusted through so I bought a Bearmach one was identical in every way to the original. Used wrecking par to leaver old one off - liquid gasket.
Don't waste your money on an original part for this |
Thanks, that’s good to know. 2007 110 TDCi Station Wagon XS
| Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 409
I had to change my sump pan that had rusted. (2015 Puma!). Anyway, it was a pig of a job. I didnt have the special tool and couldnt easily find a pry space that was not going to damage the engine block.
In the end I put holes in the sump and pulled the pan with webbing while gently trying to prise in one corner that didnt damage the block. it took me two hours! I used a genuine LR pan. about £120.00 including the special sealant. Good luck! |
Thanks Vitesse, I'm definitely going to get the separator, it's only cheap, to make the job easier. 2007 110 TDCi Station Wagon XS
I just stuffed pry bar into the back lip of the pan and used the ARB (if I remeber right) as a lever point and gave the bar a good hard pull
4year old sump pan with very nearly a hole - very bad damp spot. one I had the old pan on the flor pushed the damp spot with a screw driver (lightly) and it went through |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8486
Late 09 the sump pan design changed. 8 had a 59 plate that arrived with the original style pan that I had changed by lr. Cheers
Just a bit of an update on this. Bearmach seemingly offer both the original design and the notched sump so you need to be careful still. The original being £10 cheaper. The notched sump has A suffix on the part number 2007 110 TDCi Station Wagon XS
I’m going to swap today. Any opinion on how long I need to leave it before I refill with oil afterwards? 2007 110 TDCi Station Wagon XS
| All times are GMT |
