Home > Puma (Tdci) > Injector Refurb or not? Ballooning tip? Leaking
CaithnessDefender
United Kingdom 2007 Defender 90 Puma 2.4 HT Keswick Green
Hi,
I have a 2007 defender 90 2.4 puma it had a new 2015- short block from ford fitted at 77k miles and it’s now at 89k and still on the original injectors. Front injector seal has just started leaking causing pressure to come out the breather and some oil. I’m not sure if this is a good time to maybe get new or refurbish the injectors when I have them out anyway. It is stage 2 mapped so injectors could be working harder than normal.
What do people think? Do these injectors need refurbished ? Are they known for giving bother ?
Post #867883 17th Nov 2020 12:32pm
I am currently just shy of 250k miles and my injectors have never been out of the engine, so I would say that yours should be fine for quite a while yet.
Post #867903 17th Nov 2020 2:31pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I should think it depends on your driving style and use.
Mine does an awful lot of short journeys and quite often sits at idle whilst I'm doing jobs on the farm (naughty I know). When I pulled my injectors and had them tested , two failed . I bought two more and the difference was noticeable but not extreme.
Over the past seven years I've replaced all four injectors.
I imagine a good leg stretch weekly and some higher RPM's once in a while would do my engine a world of good ! https://www.instagram.com/hustynminepark/
Post #867923 17th Nov 2020 6:11pm
CaithnessDefender
Ballooning
I have just removed the front leaking injector and found it very dirty and full of carbon build up, the tip also looks tapered or ballooned, does this happen when the injector seal goes? Is that injector useable?
Post #868791 21st Nov 2020 5:04pm
CaithnessDefender
Post #868793 21st Nov 2020 5:10pm
Porny
Site Sponsor
Just replace with genuine spec new ones... personally never found recon to be good. Usually more of a con than a recon.
I can help with new ones if needed. IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #868877 21st Nov 2020 10:36pm
CaithnessDefender
Yeah I am going to have to replace that one anyway, the injector seat where the washer seals is damaged so likely why it was leaking. How much can you supply new ones for?
Post #868893 22nd Nov 2020 3:33am
Porny
Site Sponsor
Hi,
New genuine spec Denso injectors are £180+ vat each or £640 + vat for 4 - with all new seals and clamp bolts.
Brand new, not recon etc and no surcharge.
Can programmed to ECU and set up if needed. IRB
Post #869066 22nd Nov 2020 11:08pm
