Home > Td5 > New Defender 110 Owner - Performance and Starting Problem
Page 2 of 2 <12
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
If you clean it up super good and the area is free of crud, go to your local crappy tire and get tube of the “right stuff” (permatex amazing sealant) and seal it up with that. Great product but make sure to let it day overnight. I did one like this that lasted years. What can make it last long is to cut a small contoured piece of sheet metal to fit over the end and glue it in place. It is possible to stop the leak this way but the real fix is usually remove the t-case and a new seal. Hateful job lying on your back but easily doable.
Good luck. Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #868699 20th Nov 2020 10:33pm
roel
It all depends how bad the leak is.
Sealing from the outside works but it is not that easy. The shaft moves a little so the sealant will break loose, i made a small plate ans sealed that to the housing. That works good after multiple attempts.
The plate:
Use plenty off sealant so the plate seals to the transferbox housing and the gearbox housing. Roel
2003 90 Td5 (2009-now)
Post #868754 21st Nov 2020 12:07pm
Dobs
Canada 2004 Defender 110 2.5 TD HT Scotia Grey
This is exactly what my transmission guy is going to do (permatex right stuff) i should be good then !
For the rest, i’m waiting for the parts to come over from roversnorth
Post #869123 23rd Nov 2020 2:40pm
Page 2 of 2 <12
