![]() | Home > Td5 > White/Grey Smoke -Start Up & Strong Diesel Smell When Dr |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8458 ![]() ![]() ![]() |
Fuel leak into cylinder or water leak into cylinder , lack of compression?
Is vehicle pressurising expansion bottle? Is the grey definitely smoke or clouds/vapour is it using engine oil. Does the smell of fuel stay with you on say an hours drive or it it just there after starting? Changing glow plugs is unlikely to improve acceleration unless a plug was missing. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6035 ![]() ![]() ![]() |
Injector seals?
Oil in the red plug at the ECU? MAF sensor? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
LandyHelp Member Since: 09 Aug 2020 Location: caribbean Posts: 13 ![]() |
Thanks JST and Excossack. I was hoping the glow plugs would improve start up. Noted regarding the acceleration. Just worn out so replaced.
I will have a look at the seals, oil in the red plug at the ECU (no check engine light on though), and MAF sensor. The smell of diesel stays on in the car although I do short journeys, so maybe the car needs a good run. The entire engine was flushed out due an incorrectly installed liquid oil gasket resulting in a mess of oil and coolant mixing together but this was all cleared up. |
Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 128 ![]() ![]() ![]() |
Check the fuel pressure regulator is not leaking as this can cause a strong smell of diesel in the cab and if it’s causing a pressure drop hard starting
A bottle of injector cleaner and a good run might be just the ticket? 1999 Defender TD5 110
AT1963 Member Since: 08 Jul 2020 Location: Leicestershire Posts: 148 ![]() ![]() ![]() |
injector seals...use genuine!
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3462 ![]() ![]() |
l had a strong smell of diesel fumes in my 2005 110 when l first bought it.
l never really got to the bottom of it, tried all manner of things, but for some reason it no longer does it. lt seemed to be worse when the heater was set to hot, leading me to change the heater/bulkhead seal but that didn't cure it. Replacing the CAT seemed to make a difference but it's an expensive option, l've got a spare CAT down pipe that was bought new and only did 12,000 miles if you want to try that. |
