![]() | Home > Maintenance & Modifications > TD5 BinOwl computer |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
There is a technical problem. Tried everything even a old laptop with a serial port, different cables etc. No comm at all on the serial port.
But this is off topic. 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| Christophe Member Since: 18 Aug 2020 Location: Sint-Truiden Posts: 12
I've installed one of these in my td5, very pleased with it. Made my own housing to fit in place of the ashtray as I have access to a 3d printer. Here's the result:
Click image to enlarge 04' 110 TD5 Double Cab 10' 90 2.4tdci Station Wagon |
| kyvlle Member Since: 22 Jul 2016 Location: Essex Posts: 80
That's looks fantastic!
I see you got the small LCD version, can you see the readouts clearly from your normal driving position? I'm dithering between the LCD sizes, as I'm mainly after the engine RPM readout. |
No problems reading the data on the lcd from a normal driving position. I went for the small lcd option as I wanted to keep it sort of 'minimalistic'. Contrary to some of the dashes with a gazillion gauges that obstruct your view
| Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1181
Thanks for posting that picture up, I would be looking to do the same sort of install & positioning
| andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 369
For all UK drivers..... I bought one of these and it works great but it uses km/h and litres /hour etc for fuel consumption.
I emailed the developers and requested a firmware update for MPG and MPH and just got a reply to say it will be available with the next firmware update! Cracking service from the boys at Binowl 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Interested in the Drivers Wish feature. Do you get one per journey or is it on demand. Is it limited to the vehicle (better MPG, more speed...) or can I wish for the road to clear in front of me or the BMW behind me's engine to throw a piston...
I can't work out what that is either - maybe a way to save a preset or something? TD5 hardtop to Puma inspired Poptop - my build thread 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
| All times are GMT |
