Home > Puma (Tdci) > faulty ipod connector on puma radio
rossy
I have tried 3 different leads to connect the wife's ipod to the aux socket on the front of the radio. It doesn't grip the 3.5mm jack plugs and they just pop out.
I just wondered if anyone else has come across this and if so is it fixable or is it a new radio jobbie ? The dealer is 60 miles away so I wouldn't bother going unless there were other things to attend to and it won't be due a service until well into next year.Thanks
Post #86687 30th Aug 2011 9:13pm
The socket is recessed into the front panel of the radio, so a standard jack plug body is too big to insert fully. A genuine Apple lead or similar small diameter plug will insert properly.
Post #86696 30th Aug 2011 10:02pm
rossy
thanks Blackwolf. I'd better buy an Apple one then which will give me 4 leads in total !
Post #86708 30th Aug 2011 10:24pm
rossy
Hey just found a small diameter connector in a box of assorted crap in the cupboard under the stairs and it works a treat. Blackwolf you're a star ! Smile
Post #86719 30th Aug 2011 10:52pm
Glad to have been able to help!
Post #86729 30th Aug 2011 11:18pm
churchy
2007 Defender 110 Puma 2.4 XS CSW Java Black
Maybe I'll give that a try too!
Tried 3 leads including an Apple one and only get music through the right hand side speakers 90% of the time - its has worked through all speakers but only once!
New stereo added to the wishlist!
Post #86762 31st Aug 2011 9:27am
Buy TC's its a fab bit of kit Thumbs Up
Post #86765 31st Aug 2011 9:33am
churchy
TC'S?
Sorry if I am being thick?!
Post #86772 31st Aug 2011 9:53am
landy andy
TC is a member on here, and had a stereo for sale, in the for sale section Thumbs Up
Andy
Post #86774 31st Aug 2011 9:59am
churchy
Thanks for the tip but I believe its now sold.
Few other bits I need first anyway but always on the look out for a bargain!!!!!
Post #86783 31st Aug 2011 10:19am
Ah, that is the other problem with the standard LR unit - the socket fills up with crud and makes a poor connection. Mine was like that to start with, but jiggling the connector gently would give me stereo. Now I always leave the lead plugged into the fascia even if I remove the iPod, and it seems to be getting more reliable as time goes by. It might be possible to clean contacts by revolving the end of a matchstick or similar in the socket.
Another advantage of leaving it plugged in is that it is possible to tuck the lead into the panel joins and run it down to the cubby area, thus reducing marginally the chance of an unexpected unplugging when changing gear.
Post #86794 31st Aug 2011 11:14am
ZeDefender
Mine is also crap - finally found a Belkin lead that works most of the time...
Post #89595 17th Sep 2011 3:50pm
LR90XS2011
I had the same problem followed the advice on here and I just filed some of the plastic off the lead plug until it fitted flush with the front of the radio not had a problem since, great sound from an Iphone 4 DEFENDER 90 TDCI XS,
Post #89605 17th Sep 2011 4:56pm
