Home > Puma (Tdci) > Feels like something slipping
Sylvan
Wales
Hi all,
I was cruising up a hill doing about 50mph, after coming out of the 50 zone, I accelerated, the engian reved up but it felt like it did not transfer the power to the wheels, lifted my accelerator a bit for the engine to catch up and took it easy after that, it felt like something was slipping, I didn't try it again just in case I made it worse.
So top and bottom of it is, when I put my foot down hard on the accelerator, it revs high but doesn't pull off with the it,
I hope someone can make some sense out of what I've tried to explain.
Any help much appreciated
Bill
Post #866768 11th Nov 2020 5:41pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Slipping clutch possibly Just because you're offended doesn't mean you're right.
Post #866779 11th Nov 2020 6:23pm
landy andy
How many miles on the clutch?
Any oil leaks?
Post #866781 11th Nov 2020 6:31pm
Bluest
Does sound like a slipping clutch. 2007 110 TDCi Station Wagon XS
Post #866782 11th Nov 2020 6:36pm
Dinnu
Take care not to let the clutch slip too much as can overheat and damage the flywheel. Gearbox out to replace. While at it yoy can consider checking or replacing the adapter shaft between the gearbox and the transfer case. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #866800 11th Nov 2020 7:29pm
Sylvan
Wales
Erm maybe thanks πŸ‘
Post #866831 11th Nov 2020 9:27pm
Sylvan
Wales
71000
No oil leaks what so ever,
Thanks πŸ‘
Post #866832 11th Nov 2020 9:27pm
Sylvan
Wales
Thanks I'll go steady as usual πŸ™ˆ probably ashamed to say its never been off roadπŸ™ˆ, great thanks I'll keep that in mind. πŸ‘Thank you
Post #866836 11th Nov 2020 9:48pm
My clutch went at 44k. Is it original?
Current clutch I have is about 38k now, the first was the original generation.
The newer ones seem much better overall. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #866849 11th Nov 2020 10:35pm
Sylvan
Wales
44k, blimey, not much that tbf, how much would a new one cost fitted be these days? Thanks
Post #866865 11th Nov 2020 11:31pm
My '07 110 was on its third clutch at 44k and is now on its fifth (I think, it's easy to lose count) at 250k. The current one is overdue for replacement but has been in for 100k. The fourth lasted 60k, so they are getting better but 100k isn't great for a traditional clutch. These have all been genuine standard driven plates, I have a 4x4 Transit clutch to put in next.
I may have got through a lot of clutches, but incredibly the output adaptor shaft coupling is the original (tempting fate to say this, I know).
Post #866871 11th Nov 2020 11:48pm
Sylvan
Wales
Blimey, didn't realise they eat clutches so much 3 clutchs 44k πŸ™ˆπŸ™ˆ Unberliverble, I guess 71000 isnt to bad then, can anyone give me a ballpark figure what I'd expect to pay to have it replaced please?
Thanks for all replies, very helpful
Bill
Post #866900 12th Nov 2020 10:41am
