Home > Puma (Tdci) > Screw connecting window frame to roof
felixp
Germany
I just ripped out my headlining in order to sound proof my 110 TD4 and found out that the screw which connects the window frame to the roof was completely loose in its place. Apparently this isn't uncommon, however im not quite sure how I can fix it again.
I bought some fixing clips but I don't understand how to get them to where they should be.
Could someone please point me in the right way?
Attached is a picture for reference.
Thanks!!
Felix
Post #866716 11th Nov 2020 1:55pm
Dinnu
I think Td5 where already with self tapping screws there, not sure the size though.
See: https://www.lrworkshop.com/diagrams/land-r...mbly_44881 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #866803 11th Nov 2020 7:41pm
felixp
Germany
Thats weird because if I try to screw the old screw back in there is nothing to hold it.
I was under the impression TD4s had a screw clip to hold it in place/tighten it.
Post #866809 11th Nov 2020 7:55pm
Dinnu
I have never taken a tdci roof off yet, so I cannot be so sure, but I am 100% sure that the Td5 had self tappings (2003 model for sure). I cannot remember if there was a clip on the roof to accept the self tapping.
The earlier Defenders had an M6 bolt there (M6 thread on the roof). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #866813 11th Nov 2020 8:29pm
TD5 and TDCi have the same roof and fittings. Sounds as though either there's a hole with a stripped thread or a spire nut is missing. What's on the other side of the car?
Post #866815 11th Nov 2020 8:33pm
Dinnu
I re read your question.. sorry I read it too fast before. And now see quite a large hole where the self tapping should go into.
It is possible that part 302532 have to go 'behind' the hole. The top rail of the roof has large holes where the nut plates that fix the top of the windscreen go. But the last one if still quite far from the corner (unless you have a finger which is 20cm long Rolling with laughter )
Perhaps you can tape the insert to a cable tie just to push/guide it in place from the last hole. Once you get it close, use a small screwdriver to get it into position. I think there should be a slot where it slides into, but will be hard with the roof in place. You can then pull the cable tie if the tape that you use is not strong enough. Or just leave it in.. it will not corrode or rattle.
Not any easy one without removing the roof. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #866818 11th Nov 2020 8:42pm
felixp
Germany
Im pretty sure its a spire nut. Ill try to figure out a way to get it where it has to go..wont be easy though Sad
Post #866824 11th Nov 2020 9:00pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Should be either an M6 bolt, as mentioned above, or a 6.3mm self-tapping screw, probably x19mm - quite common and still used to hold the sunvisors.
With our pop-top roof an M6 bolt rattled loose in exactly the same place as yours - Icelandic corrugation Smile
However, the roof's frame is a few mm thick and had an M6 thread (now knackered) so it was an easy bush fix using said 6.3 screw. Didn't last long though and in the end I cut am M8 thread.
Post #866861 11th Nov 2020 11:13pm
felixp
Germany
Thanks, that might actually be a good option! Smile
Post #867021 13th Nov 2020 8:04am
