- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Td5 > New Thrust Washer ERR5345LR Wont fit on Defender TD5 Engine |
stevejohns72
| New Thrust Washer ERR5345LR Wont fit on Defender TD5 Engine | |
Hi Guys
This is Steven T. Johns
I recently tried to overhaul my LandRover defender TD5 engine with VIN SALLDHM584A682480. I removed the old thrust washer and replaced it with a new one with part number ERR5345LR, bought from FirstFour Offroad Ltd. Unfortunately, the new washer can not fit in the space. It seems to be a bit thicker than the old one. Is there anything I am doing wrong? I was told that all the thrust washers for the TD5 engine, are of the same thickness.
I also noticed some numbers on the parts. On the old thrust washer I saw a inscription FM1704 whereas on the new thrust washer I saw the number 4604.
Can anyone guide me as to what to do?
I greatly appreciate your input!!!
10th Nov 2020 11:26am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
