![]() | Home > Technical > Bigger Wheels - Speedo? |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
https://www.land-rover-blog.co.uk/how-to-r...and-rover/ you find this rear of the transfer box under the green transponder and it can be a plan to remove
or https://www.ashcroft-transmissions.co.uk/s...-c102.html Last edited by dorsetsmith on 8th Nov 2020 7:17pm. Edited 1 time in total |
| robrennie Member Since: 20 Mar 2018 Location: Somerset Posts: 28
Thank you Sir!
| camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3417
How big you going?
The speedo already over reads on the standard tyres. If you go to 33 inch tyres (285/75/16 or 255/85/16 equiv) it will read almost bang on. If you go taller than that, it will underread. |
| Organised Chaos Member Since: 20 Dec 2008 Location: Chesterfield Posts: 57
Some where in the back of my mind, you can program the tyre size into the instrument pack using the nanocom, did this along time ago when i went from 750 tyres to 235 tyres, it also then gave me the option to up the speed limiter from 82mph to 90 mph but left it at 82.
Thanks for that - I did wonder if it was programmable.
I am getting the wheels sorted then off to Ashcroft Transmissions for an auto box to be fitted - if it is a reprogramming job, then might be something they can do. Cheers, |
Ashcroft supply a speedo correction kit for the puma for £75
So they do!! - thanks for that
| All times are GMT |
