Home > Td5 > Td5 Wipers
chrispaylin93
United Kingdom 2005 Defender 110 Td5 XS DCPU Santorini Black
Td5 Wipers
Hello Hello,
Recently my drivers side windscreen wiper started to play up went from working fine then gradually got weaker then intermittent working and not working and now no movement at all! It’s not seized as I can move the wiper manually! I get the feeling maybe a spline has been stripped?
If this was the case I presume access it by removing dash/dials!
Any help would be much appreciated!
Chris
Post #866036 8th Nov 2020 12:08pm
jimbo55
Assuming that the passenger side wiper is still working correctly, will most likely be the wheel box that has stripped. Quite a common problem and isn’t difficult to swap. Does require the top panel of the dash to be removed as well as the instrument binnacle
Post #866046 8th Nov 2020 12:43pm
chrispaylin93
Great thanks for your help!! I’ve never taken a dash apart to this extent before! Can you tell me where about is the wheelbox? I’ve got the top part of the dash away and also all the dials! Do I need to remove the vent for blower to windscreen?
Thanks
Post #866067 8th Nov 2020 2:36pm
chrispaylin93
Is this the wheelbox? The rod is still moving
Post #866071 8th Nov 2020 2:47pm
chrispaylin93
It’s looks to me that it’s the mechanism underneath rather than the actual wheel
Post #866075 8th Nov 2020 3:07pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Wiper rack? PN DLE000010. Rather easy fix if that is the culprit. Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #866078 8th Nov 2020 3:30pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
wipers
The main culprits tend to be the wheel boxes becoming stiff with corrosion over time then either seizing or wearing excessively on the gear that drives them- and eventually binding up on the rack.
Sometimes you can be a wee bit sneaky and flip the gear wheels through 180 degrees to drive on the non-worn section.
They are a relatively easy, but faffy fix requiring a fair amount of dismantling of the dashboard.
If you are going to go to the effort of changing them its worth doing the rack as well- and inspecting the gearbox on the motor.
Edit: there are splines on the spindles and the wiper arms, if these have been slack then they can sometimes wear so the wiper just rotates freely.
Regards
Chris
Post #866084 8th Nov 2020 4:01pm
jimbo55
I agree with Chris, if you’re going to the hassle of dismantling your dash that much to swap one you may aswell change both and the rack for peace of mind.
Post #866128 8th Nov 2020 7:11pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
I think that there are some good Youtube videos on the subject and LRO International did a good article about it. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #866232 9th Nov 2020 10:02am
