![]() | Home > Maintenance & Modifications > Battery charger recommendations |
AT1963 Member Since: 08 Jul 2020 Location: Leicestershire Posts: 148 ![]() ![]() ![]() |
You wait until you have a big battery to charge (the one instead of your engine)
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6035 ![]() ![]() ![]() |
In what way.? 1999 Defender TD5 110
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 ![]() ![]() |
Ctek user here too! Kept the 110 on trickle charge for ages through covid19 and can't fault it.
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Have a Dometic IU1012 installed in the seat base and a ip67 connector on the rear cross member to be able to charge the car without too much hassle. Don’t use the car as much as I used to.
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1258 ![]() ![]() |
I also have a connection point hooked up full time
![]() Click image to enlarge12v3 by Richard Holmes, on Flickr 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 1990 Defender 200tdi CSW (sold) 1989 Land Rover Ninety (sold) 1998 Discovery 2 (sold) 1995 Discovery 1 (auto) (sold) 1990 Discovery 200tdi (sold) 1987 One Ten CSW turbo diesel (sold) |
I have also a Ctek something with 25
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
None of us are ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
northernerindevon Member Since: 28 Feb 2018 Location: Bristol Posts: 62 ![]() ![]() ![]() |
Another CTEK user here.
Mine gets left on for weeks or months at a time when I am away with work. Fit & forget. I see they sponsor Harrys Garage too. Good enough for Harry, good enough for me... |
Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 371 ![]() ![]() |
Amazon have good prices on the CTEKS at the moment. It started with a kiss, never thought it would come to this.
SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 950 ![]() ![]() ![]() |
I am now torn whether to give a cheaper option a go or spend more for one of these ctek ones, they seem to be well regarded by many on here...
I do tend to believe in buy quality that lasts but a cheaper one may be fine anyway! |
I think the Ctek is worth the money, as said it re sets after it has been disconnected and also has the added advantage of a recon mode which normally fixes most battery issues. The other advantage is it fits inside a B&Q waterproof box so it's waterproof if need be, you can see it in the orange tube (less than £5)
![]() Click image to enlargedinitro2 by Richard Holmes, on Flickr 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 1990 Defender 200tdi CSW (sold) 1989 Land Rover Ninety (sold) 1998 Discovery 2 (sold) 1995 Discovery 1 (auto) (sold) 1990 Discovery 200tdi (sold) 1987 One Ten CSW turbo diesel (sold) |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4337 ![]() ![]() ![]() |
I’m pretty sure Cteks are IP65 anyway, so ok as as you don’t immerse them. 2007 110 TDCi Station Wagon XS
ah I did not know that. I went all belt and braces anyway given it sat like that for weeks during lockdown 1. 1984 One-Ten CSW
Whilst CTEKs are reliable ~ one of mine has been permanently plugged into a vehicle for over 8 years; I did have an issue with another unit when the mode button would not cycle through the options. The warranty replacement process direct with CTEK was very organised and I had a replacement unit within a relatively short period of time.
