Home > Technical > TD5 Squealing
Joel
United Kingdom 2002 Defender 110 Td5 DCPU Santorini Black
TD5 Squealing
Morning folks,
My TD5 has a squealing noise - seems to happen when accelerating, and then when you turn it off, there is a short squealing noise.
Is it likely to just be a belt, or could it be bearings in something?
Post #865672 6th Nov 2020 10:11am
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Short squeal will be the crank pulley - it has a rubber damper in it.
The long squeal on acceleration will most likely be an exhaust manifold leak - have a look around the edge of it for signs of soot. You’ll probably find a broken stud or two as well. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #865674 6th Nov 2020 10:16am
ibexman
Exhaust manifold. Maybe
Post #865675 6th Nov 2020 10:17am
Joel
Lovely. Do Defender TD5's suffer the same manifold warping as the Discoveries?
It does feel a little down on power sometimes, so i wonder if it is a manifold leak causing lack turbo.
Thanks.
Post #865680 6th Nov 2020 10:21am
nosnibod
Yes they do, unfortunately. Depending on the size of the leak it could in theory reduce boost pressure. Main symptom when my old Td5 had the same problem was the whistle/squealing sound. Dave
Post #865682 6th Nov 2020 10:24am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
There is a good troubleshooting article in LRO International this month, especially warped manifolds and broken studs. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #865683 6th Nov 2020 10:28am
landy andy
Check at either end of the exhaust manifold for soot or loose/broken studs.
Post #865711 6th Nov 2020 2:41pm
Joel
I don’t think it’s manifold, I can’t see any obvious signs of an issue.
I am beginning to think it’s either belt related, or pulley / tensioner.
Seems to be worse after a bit of water, so am guessing a belt is slipping or a pulley bearings are shot.
Post #868513 20th Nov 2020 10:10am
dorsetsmith
Drive Belt tensioner or idler or alt bearings are shot. remove belt and check each bearing
Post #868521 20th Nov 2020 10:48am
