Home > Maintenance & Modifications > Puma 2.2 Intake to airbox
Page 2 of 2 <12
Roy5695
The cowl I have where the air intake used to be is made for LHD vehicles to re-route the blower intake. Sold by nakatenenga πŸ‘
Tyres are 265s on 18”. ET0 which makes them poke out a bit πŸ‘
Not sure what you’re asking James? Comparison of sizes?
Airbox inlet is about 100mm. Pipe is 102mm internal diameter. Wingtop adaptor is 100mm internal diameter too. πŸ€·β€β™‚οΈ 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #865437 4th Nov 2020 9:35pm
keith
I also went for the β€˜ under β€˜ option with the flexi pipe. But I have my silicone connector going into the airbox rather than over it. Still to paint the connector within wing vent black where it won’t be seen.
Post #865760 6th Nov 2020 7:15pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
The option I’m thinking of for my td5 is using a genuine heater intake for a LHD car and fitting it on the drivers side wing top with a kbx scoop or snow cowl. It has a 4” exit hole at the end. With some sealing strip I think a 4” silicone hose with wedge tightly into the back. As mines a td5 I’m probably going to get a 4” to 3” reducing elbow going straight down at the back then a stainless 90 and it will be almost the same position as the stock intake pipe then use a 3” flexy to the airbox. It looks like you could you the same with a puma using a 135 degree elbow out the back of the heater intake.
Post #866090 8th Nov 2020 4:41pm
jimbo55
LandymanStefan, why reduce to 3” when you can run 4” to the airbox? Does mean cutting some of the filter intake off but is definitely worth while doing especially if you’re td5 is highly tuned.
Post #866127 8th Nov 2020 7:09pm
LandymanStefan
I dont think a 4" will fit below the steering arm. Td5 isnt tuned as yet, just getting all these bits ready for when it is. 3" is still considerably bigger than the stock td5 intake.
Post #866129 8th Nov 2020 7:11pm
jimbo55
No 3” doesn’t fit underneath so has to go over the top, the pictures in my earlier comment show how I did mine
Post #866131 8th Nov 2020 7:16pm
LandymanStefan
You mean 4”? If I go with the wing top lhd heater intake with a 4” it would look daft zig zagging back on itself to go over the top, i think id need a couple of 180 bends. 3” will go underneath fine and should look quite neat.
Speaking of neat your 3D printed side intake looks great. Thumbs Up
Post #866138 8th Nov 2020 8:05pm
Page 2 of 2 <12
