![]() | Home > Td5 > Td5 having problems getting into reverse and 1st. gear |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6015 ![]() ![]() |
Check clutch adjustment and change the box oil would be my starting choices.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 998 ![]() ![]() ![]() |
You can try to reset the bias springs on both sides of the shifter tower. Normal wear and being out of adjustment often causes hard engagement of gears.
Good luck ![]() Click image to enlarge 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 803 ![]() ![]() ![]() |
Hello,
Wear in the turret can also make some gear selection imprecise and difficult to select. Regards Chris |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17980 ![]() ![]() ![]() |
If it's ok with the engine stopped and not with it running it will be clutch or spigot bearing.
True, read the OP and missed that somehow
![]() 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 ![]() ![]() ![]() |
I had that problem for a long time in combination with a terrible nose. Typical spgot bearing but I had the clutch, flywheel etc replaced at the same time since the mileage was 180 000 km. The noise is gone and it is easy to select gear.
//Hans |
Lionel Member Since: 12 Aug 2008 Location: Melbourne Posts: 60 ![]() ![]() |
Sound like the clutch is not releasing properly. There are a number of possible causes for this. I would check: 1. Fluid level in clutch master cylinder. If OK, it is still possible that there is air in the system, particularly as you are not sure of the vehicle's history. Try bleeding the clutch. If low, check the hydraulic line & both master & slave cylinders for leaks. 2. Check the pedal adjustment. There should be a small amount of play in the pedal (5mm or so). If excessive, you will need to check adjustment in the pedal box under the bonnet. 3. By your description of no noises or no slipping, it is less likely that the clutch unit itself is causing the problem. Cheers, Lionel |
Photographereden Member Since: 02 Nov 2020 Location: Victoria Posts: 3 ![]() ![]() |
Thanks mate, all good now 2 mins done cheers
andylee Member Since: 29 Jun 2016 Location: South East Posts: 99 ![]() ![]() |
Out of interest what suggestion fixed this issue?
I also have a 2003 CSW with the same issue with 1st and Reverse only... thanks A |
Very easy, I just adjusted the master cylinder a little bit, now is very smooth
The Crab Botherer Member Since: 07 May 2020 Location: WIRRAL Posts: 56 ![]() ![]() ![]() |
Nice result!
i had very similar issues but it turned out to be a combination of pedal height/ m/cyl adjustment and turret adjustment. |
