Home > Puma (Tdci) > Under seat wiring loom
Ninja man
Hi, can any one tell me what the spare connector under the drivers seat heater loom is ,next to where the loom exits the seat box to connect to seats. It has pink,Yellow, blue/purple wires
Post #864794 1st Nov 2020 6:09pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Is it orange instead of yellow, maybe? Could be C2004/C2005 connecting the rear doors (blue/purple door switches, others central locking motors).
Post #864852 1st Nov 2020 9:45pm
Ninja man
Thanks for the reply, does that mean one of them could be live when ignition is on to allow a feed to a switch and then a relay to power a work light?
Post #864872 1st Nov 2020 11:00pm
Martin
Site Admin
Nope - none of those is an ignition feed.
If you have a 90 it's unused, it's the connector for the second row doors - central locking motors and door switches.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #864934 2nd Nov 2020 11:12am
dorsetsmith
who about purple wire that go drivers side rear 20 amp fuse not switch by ignition ?
Post #864954 2nd Nov 2020 12:57pm
Ninja man
Sadly the purple wire is not present on mine as it’s 2014 and they apparently stopped putting it in 2013 , I am sure there must be something under the seat that is switched after ignition if not I’ll have to take one off of a wire behind the dash as I’ve got to fit a switch there anyway but thanks for your help all of you. I only wanted a work light that switches on at the dash via a relay under seat but it’s proving to be a right ball ache to do it properly Rolling Eyes
Post #865056 2nd Nov 2020 8:05pm
Ninja man
If it’s unused does that mean it’s not connected either end or could I fit a relay in the appropriate place and instead of powering windows power a light ? Probably grabbing at straws but electrics in defenders never seem logical or it’s possibly just me
Post #865060 2nd Nov 2020 8:13pm
Martin
Site Admin
It's unused as you don't have the second row of doors. It's connected to the alarm ECU at the other ends of the wires Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #865062 2nd Nov 2020 8:20pm
Ninja man
Ok that’s fine I’ll stick to plan A and delve in behind dash, thanks for your help ,much appreciated Thumbs Up
Post #865063 2nd Nov 2020 8:24pm
