Home > Maintenance & Modifications > 2008 Puma 110 DCPU Front diff failure.
Page 2 of 2 <12
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Yes both parts of the snapped pin loose in the bottom as well as the two gears. Very surprised it didn’t fail more spectacularly and cause more damage. Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #864481 30th Oct 2020 8:11pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Anyone manage to catch this before it occurs in such spectacular fashion? Are you able to see this elongation from the oil drain/filler with an inspection camera?
Post #864578 31st Oct 2020 12:58pm
You probably could check for elongation through the filler hole.
Post #864583 31st Oct 2020 1:32pm
Dinnu
Is this the result of too much wheelspin? Or poor quality?
I expect for 4 gear diffs, the pin cannot rotate in the housing. All rotation is between spider gear and pin.
Perhaps for the 2 gear diff, would be smart to glue the pin to the housing and any wear will be in the spider gears or the pin itself. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #864611 31st Oct 2020 6:07pm
On a two-gear diff the pin cannot rotate until the locating roll-pin breaks, which invariable happens. The root cause is the Puma engine is too powerful for the single cross-pin to sustain - bear in mind that the entire front driveline power is transmitted through that single pin, and the contact areas between the pin and the diff cage is relatively small. Bottom line, the diff was not designed for an engine with some much torque in a farily heavy vehicle and longevity suffers as a result.
Landrover acknowledged this at the rear and fitted the P38 4-gear diff to LWB TD5 and TDCi Defenders, and sort-of acknowledged it further by then designing the 4-gear Rover pattern diff to fit the standard diff carrier, and even said that the 4-gear diff would be standard in the front of the LWB vehicles. I have never seen an explanation why, after doing and saying this, they clearly failed to fit them them in a great many LWB vehicles.
The relative weakness of the Rover pattern diff has been known for years, which is why the IIB had ENV axles, the earlier LWB and uprated vehicles had Salisbury diffs. One can only assume really that towards the end the people who worked at Landrover were too stupid to understand the engineering learned by their predecessors or simply didn't care.
Post #864615 31st Oct 2020 6:24pm
ickle
Just an update, it is possible to check for impending doom through the filler with a little inspection camera, probably better to drain the oil and flush with a spray of paraffin or similar to be 100%
Post #878920 16th Jan 2021 6:51pm
Page 2 of 2 <12
