Home > Maintenance & Modifications > Rear window seals & filler strips
tyre fitter
United Kingdom 1986 Defender 90 200 Tdi PU Nato Green
Right I need to clear something up 😄
My 90 county van on the rear quarter windows has the window seal filler strips on the inside, my mates 2015 defender has the filler strips on the outside which I was abit concerned about security wise. Also my county windows are externally beaded... Which is the right way? Or does it depend on which day it was built or who built it??
Post #432237 19th Jun 2015 8:37pm
mk1collector
If you mean the little ones on the back the beads should be on the inside, but it really makes no difference for security as the windows can be removed in seconds either way. Ray
My build thread
Post #432268 19th Jun 2015 10:21pm
izack98
Canada 2001 Defender 110 2.5 TD CSW Chawton White
Just reviving this thread. Does anyone have any tips on reinserting the rubber 'lock strips' into the channel once the 1/4 glass has been reinstalled with new rubber? I got the new rubber in, fiddled with the glass and finally got that in. I am now wanting to insert the lock strips into the channel on the inside. It's pretty tight.
Post #864530 31st Oct 2020 1:59am
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
You need a Claytonrite tool
Somethign similar to this
https://www.ebay.co.uk/i/163428377027?chn=...TvEALw_wcB
Post #864534 31st Oct 2020 9:04am
izack98
Ah yes. Thanks Landyman! I have seen those.
I will pick one up. A screwdriver and a bunch of cursing just wasn't working.
Post #864616 31st Oct 2020 6:37pm
