![]() | Home > Maintenance & Modifications > Side protection |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8375 ![]() ![]() ![]() |
They were originally made for challenge scene at the time traybacks were starting to evolve. As traybacks gained 8n popularity you didn't see the tub rails/sliders quite as much. Some also join into door sliders, and some go around the back towards rear door as you say.
Mine came from xeng but they only supplied them fir a limited time. So like this but going around the rear towards the door https://uproar4x4.com/products/land-rover-...ub-sliders Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
https://www.famousfour.co.uk/new_parts/ff_part?part=13493 Cheers
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 ![]() ![]() ![]() |
![]() ![]() Thanks for the links ![]() ![]() |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
if you get ones which are solid you can rest your tea mug on them too!
its only 75mm x 50mm ali section, could always get a local fabricator to tig some up? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Like the look of those ![]() Chris |
