Home > Puma (Tdci) > new vcv fitted runs fine till......
pme
United Kingdom 2007 Defender 90 Puma 2.4 SW Tonga Green
Hi
had some issues with hesitation replaced fuel filter and then vcv, finally running fine, seems to pull well, but if I push it in 4th to 3500rpm i get a hesitation like a rev limiter.
Searched hi and lo and failed to find any factual info on rev limits.
Engine is totally standard, no aircon. around 116000km
No re learn carried out yet.
Does anybody have any insights to suggest next steps
Thanks
Chris
Post #841274 2nd Jul 2020 12:54pm
ickle
I thought VCV has to be set up electronically?? Probably just running on default settings......
Keith
Post #841350 2nd Jul 2020 7:15pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
You will need to complete a full relearning cycle before carrying out further fault finding.
Note that I've had a similar issue to that with a faulty fuel filter, it was a Bearmach own brand filter and had a deformed interior when taken apart with a key part missing. It used to hesitate when revved just above 3k and then carry on as normal. Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #841366 2nd Jul 2020 8:21pm
It really shouldn't be necessary to do the pilot learn when changing a VCV. There are plenty of people here who've done it without issue. Darren
Post #841401 2nd Jul 2020 10:18pm
Exactly as above for me when I changed mine.
No problems at all.
Check your MAF & MAP sensors. Possibly now you’ve replaced the VCV the other items parameters are not being met due to faults and or being dirty.
Failing that, the VCV maybe at fault it’s self which would be a pain.
I simply swapped mine and job done and been running better than ever since, but I do have almost new MAF & MAP sensors. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #841405 2nd Jul 2020 10:27pm
pme
Ordered an odb box to run with forscan, I'll try a relearn, its quicker than getting a filter down here, Off to the big city next week, i'll try and get another filter.
Anybody else had the filter issue?
Maybe our friends in china are into "clap" copy fuel filters now
Thanks for all the suggestions
Post #841480 3rd Jul 2020 12:29pm
pme
finally fixed
Much head scratching at a local independant, some diesel bug present after treating with enzyme, still bad running above 3k.
Tank out, cleaned inside, bit of crud and fuel bug removed
In forscan you could see target rail pressure was not being met.
Finally crankshaft position sensor removed, the end had been chewed a bit, seems like when the rear crankshaft oil seal was repalaced as part of the clutch replacment the sensor was incorrectly fitted.
New sensor and away we go.
Why it caused the fuel rai pressure to drop is a mystery.
Post #864080 28th Oct 2020 7:31pm
