Home > Maintenance & Modifications > 5w30 Synthetic Oils
AdrianCR
2016 Defender 110 Puma 2.4 XS CSW Scotia Grey
5w30 Synthetic Oils
Greetings mates. My Defender just got off warranty, so Im not obliged to use Castrol 5w30 Magnatec anymore. Options are Valvoline, Mobil1, Repsol and Quaker State. After some research on the web I was impressed by Quaker State, they challenged Mobil1, Castrol and Valvoline for several wear tests to prove Quaker State is the best. Such companies declined the challenge. This pretty much convinces me to go for Quaker State, but somehow I feel its just marketing. My local dealer offers only Repsol and Castrol, should I stick to either one of them or go for Quaker State? Or Valvoline, Mobil1. My priority is to get the best protection for achieving as many miles possible out of my Puma. Cheers Thumbs Up
Post #86378 28th Aug 2011 6:09am
rossy
Hi Adrian
there are many posts on oil in the archives if you do a search and it seems just as many opinions as to the correct one to use. Also, in hotter climates, dealers and forum members use specs and viscosities that wouldn't be suitable in, say, Europe. The one bit of advice common to all is frequent oil and filter changing - either every 6k miles or twice a year. Magnatec is the recommended WSSM2C913B spec and in the last year or so has suddenly become fully synthetic where it used to be semi. But my dealer uses Castrol Edge 5-30 in everything as they buy in bulk and it seems to be a one size fits all quality oil . Yet Valvoline is just as good and miles cheaper (no big marketing budget to pay for unlike Castrol). I use Magnatec only because I got a bulk order cheap ( � 22 per 4L container which is cheap for here) so you pays your money..
Never heard of Quaker State. This side of the Atlantic they make porridge ! Laughing
Post #86382 28th Aug 2011 7:40am
Naks
Re: 5w30 Synthetic Oils
I would stick with a fully synthetic oil that meets Ford Spec WSS-M2C-913C. Mobil 1 is probably your best bet Thumbs Up --
Post #86384 28th Aug 2011 8:31am
MK
Bear in mind that not all 5W-30 suit the Ford spec. M2C913B can be replaced by 913C which, in this case, is in deed a better spec with higher soot handling capacity. M1 does not meet the spec. Only Mobil Super 3000 X1 Formula FE 5W-30.
From Mobil : ".......LR requires the ACEA A5/B5 spec, but only recommends the Ford spec......" Thumbs Up Puma 110" SW
Post #86387 28th Aug 2011 9:07am
Naks
MK, what oil are you using? Does it make a difference when compared to the Castrol LR uses?
IIRC Agip is a good brand as well? This one fits the specs - Agip FORMULA ECO F: http://www.ndi.eu/Olie/Produktdatablad/For...%20SDS.pdf --
Post #86426 28th Aug 2011 7:59pm
MK
80% Of my miles are on long distances ie. non severe conditions. A 913A or B oil does not last 10000 km according to my oil tests (5000 km is ok. At least on my vehicle). The 913C goes well up to 7500 km of use on non severe conditions.
I`m using Motul Specific 913C. The AGIP oil you mention fits perfectly to your needs I would say. But bear in mind it probably will not last 10000 km like LR claims. Thumbs Up Puma 110" SW
Post #86430 28th Aug 2011 8:19pm
Naks
Wow, only 5000km!? What levels of sulphur is present in your diesel? In South Africa I only use diesel with 50ppm, but sometimes when going into the rural areas or Namibia you only get 500ppm, so after a long trip I always change the oil.
I also change the oil every 10000km regardless.
I am trying to get the Mobil Super, but no one sells it in SA, so I have to find something else. I also doubt that I will find Agip.
There is always LiquiMoly? --
Post #86435 28th Aug 2011 8:28pm
MK
We have both types of diesel fuel (high and low S). I was also changing the oil every 10kkm, but anymore. IIRC the min. TBN value for A5/B5 is aorund 8 mgKOH/g, which seems not to be enough. I could replenish my sump with a few lithers of new oil, but I rather change the oil. If the weather over there is quite hot then a 0W-40 should be fine. After a few thousand clicks its viscosity drops nearly to a 5W-30 but it has a starting TBN of 10.
Believe it or not the Australian Penrite oil has a 5W-40 oil meeting the Ford specs. Puma 110" SW
Post #86437 28th Aug 2011 8:56pm
Naks
MK wrote:
If the weather over there is quite hot then a 0W-40 should be fine. After a few thousand clicks its viscosity drops nearly to a 5W-30 but it has a starting TBN of 10. Believe it or not the Australian Penrite oil has a 5W-40 oil meeting the Ford specs.
I also agree, in non-EU climates, the oil should be a 40. Unfortunately my landy is still under warranty, so I have to use the Castrol A1 Professional or something else that conforms to the 913C spec.
If we had that Aussie Penrite oil in SA, I would definitely use that! --
Post #86469 29th Aug 2011 8:01am
landylash
Pakistan 2009 Defender 110 Puma 2.4 SW Tonga Green
hello.i think one of the biggest question still remains why and what type of oil do we use.here in pakistan 8months the climate is hot . the biggest problem with using fullysynthettic oil like mobile1 with me is oil expires in the sump before it is on the road. some says it is better to buy toys for your kids rather to buy expensive synthetics which you could not use to there limit.landrover wenders gave me three different types of oil to try caltex havoline energy 5w30 .exool from uk5w30.and the last one is kendall from conocophillip5w40 titanium liquid.personally i like havoline and kendall. it gives me good millage .good starting and efficent engine noise.should i be using kendall in extreme hot conditions or come back to landrover recommended 5w30 still remains a big question. Question
Post #86571 30th Aug 2011 12:59am
Naks
Information that I gathered online about the oils meeting the Ford spec WSS-M2C-913C, may be useful:
From Opie Oils
Agip Formula ECO FO
Caltex Havoline Energy 5w30
Fuchs Titan Supersyn F 5w30
LiquiMoly Leichtlauf Special F 5W-30
Motul 8100 Eco-Nergy 5w30
Penrite HPR Diesel 5w40 (only conforms to M2C-913-A/B)
Shell Helix Ultra AF 5W-30
Unfortunately for me, other than the LiquiMoly, none of them are available in SA. I hope you fare better in your country. Btw, also look at the viscosity at 100C of the oil you are buying - the closer it is to 12.5, the better. --
Post #86599 30th Aug 2011 12:02pm
Lorryman100
Why not use an Ester Fully Synthetic engine oil instead of the modified mineral Fully Synthetics?
http://www.defender2.net/forum/topic7647.html
Post #86643 30th Aug 2011 5:43pm
Naks
Ester synthetic better than mineral synthetic I take it?
Looks like only the Motul SPECIFIC 913C 5W-30 is ester and 913C
What's the difference between PAO(?) and ester synthetic? --
Post #86657 30th Aug 2011 6:43pm
