Home > My Defender > My Cat-S 65 plate 110 XS CSW
s55shh
I bought this recently knowing that it had been in a single vehicle accident, off road, in soft mud, involving it falling over! Obvious damage was wing and door plus a kink in the side of the roof where the roof bar was mounted. All bolt on parts. However, the reason it went Cat S seems to be this chassis damage where the side step mount pushed in.
I'm wondering if anyone has experience of pulling out a dent in the side rail of the chassis. I'd like to have an autolign inspection to get the Cat S changed to Cat Inspected but there's no way I'm fitting a new chassis for this cosmetic damage.
Post #863507 25th Oct 2020 7:40pm
hank
Outrageous classification! Are there any holes on the other side of the leg you can get a drift in to hammer the dent from behind? > 110 XS Double Cab
Post #863509 25th Oct 2020 7:46pm
ickle
Use the captive bolt to pull that area out & bolt some more steps with a spreader plate under to cover 'the damage'!
Keith
Post #863511 25th Oct 2020 7:59pm
The daft thing is that there is absolutely no need to repair that "damage", it isn't doing any harm at all.
Post #863513 25th Oct 2020 8:12pm
gcc130
You could cut a section out and flush weld a repaired plate in.
Post #863520 25th Oct 2020 9:15pm
williamthedog
Leave it as it is, just dinitrol over it and you wouldn't notice.
Post #863532 25th Oct 2020 10:19pm
