Home > General & Technical (L663) > Incoming - 2020 HSE Eiger Grey |
umbertob Member Since: 21 Jun 2020 Location: Altadena, CA Posts: 133 |
Welcome, fellow Southern Californian.
4. They definitely do fold flat on a 5-seater. If you have a 5+2, I don't believe they do. 9. The climate control dials next to the shifter double as heated + cooled seat controls. Briefly push the left or right rotary dials to access the front seat warmers and coolers, then turn dial left to cool or right to heat. I love the HUD in mine, specifically because it is so bright (and I can still see it through my sunglasses in bright days.) You can adjust the brightness down until it is barely visible. Matter of taste, I guess. Congratulations, beautiful color. 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround |
21st Oct 2020 7:48am |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 |
Click image to enlarge 22’s should be fine on snow and light off road. |
21st Oct 2020 9:04am |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3750 |
Welcome to the forum
Middle row seats will fold flat if you press them down firmly until there is a click - there are posts about this in the forum and Offroad Adventures has a video on YouTube showing how to do it. Locks - I suspect that part of the improvement s to prevent signal grabbing has been a reduction in signal power as I often find what you report about pressing the square and nothing happening even though you have the fob in your pocket. I’ve found that having the fib in the same pocket as a cellphone/ mobile phone or other keys in the pocket shields the fob signal and since making sure that I don’t put my phone into the same pocket and I am closer than half a meter to the car it opens every time. You do have to stand a lot closer to the car than I recall on other Land Rover products. Heater controls - in the setting menu did you know that you can also select “sync” mode so one knob operates both front controllers? I cannot help with the rear Aircon as I only have dual zone not three/ four zone however, I thought that there was a rotary knob in the area of the 3rd row seats that has a 0 (zero/off) position, is there nothing the same for the middle row on the back of the centre console? I found the way to switch off the rear ac/ climate in the iGuide - see the photo below - in the centre controller there is an on/off icon - suggests to me that you press that button in until it goes to the off position. Click image to enlarge 22” wheels/tyres in the snow - I ran both a TDV8 and an SDv6 RRSport on 22” wheel for 3 years each and had no problems in 3-4” depth (we rarely get more than than here in Central Scotland) - you can use Terrain Response on the road in the Grass, Gravel and Snow setting although some people say that Sand mode is also very effective in snow. I would suggest that you find an area of wet grass and have a play with the TR settings because the amount of throttle damping programmed into the GGS setting can be a bit of a surprise first time you use it! It does work and I found it gradually allowed me to increase speed almost up to Highway type speeds on compacted snow on summer tyres, as soon as it senses wheel slip it deadens the throttle and reduces your speed. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
21st Oct 2020 9:19am |
landiepete Member Since: 31 Aug 2020 Location: Norf Posts: 18 |
You know, everyone is entitled to their opinion, but are you sure you drove one with leather and not MB-Tex ? |
21st Oct 2020 12:56pm |
edubyaang2 Member Since: 21 Sep 2020 Location: Los Angeles, CA Posts: 4 |
I drove the MBTex, and that is all the dealer had for all GLS. They said they had to special order the Nappa leather for me to try.
21st Oct 2020 5:57pm |
Re Seat Folding. I have the 5x2. While the 3rd row lays flat the middle row definitely does not...
21st Oct 2020 5:58pm |
I have the 3-zone Climate Control with the 2nd row temperature dials, and pushing that center button does nothing, despite the icon on the button and instructions implying otherwise. System stays on. Turning the dial does change the speed of the fan for rear passengers from Auto (unless the settings are locked via the front touchscreen.) It's a bit silly that you cannot turn it off, but the power button is also missing from the "2nd row" climate controls on the front touchscreen, so I guess it was designed to stay on for whatever reason? First and third row can be turned on or off from the touchscreen or manually, so that's just weird. Another small thing that bugs me and makes me think that LR didn't really test their UI as much as they should have - or they would have caught stuff like this prior to launching the vehicle - is that the adjustable temperature for the 2nd row's climate control is always displayed in degrees Celsius on the touchscreen, even if you switch the car settings to Fahrenheit (the rotary dials for the rear passengers display Fahrenheit, however.) Edit: You can only turn the second row on or off along with the first row, not independently. Anothere weird thing is that changing the speed of the fan using the center dial in the second row also seems to change the speed of the vents fan in the first row? Best to leave everything on Auto. 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround |
21st Oct 2020 6:24pm |
Ah thanks for the tips. On the snow issue, in the winter here, either snow tires or snow chains are required. Are chains available on a tire this size?
21st Oct 2020 6:47pm |
nickp Member Since: 17 May 2012 Location: Surrey Posts: 19 |
Hi, must agree with Tim in Scotland, I have the 5+2 and if you really push the second row seats down they will engage with a click and are as near as damn it flat
Cheers Nickp
21st Oct 2020 8:07pm |
That's a bit unfair, of course, as the MB-tex isn't leather. I also think the GLS is an odd match to compare to a Defender. And the GLS is a hell of a lot bigger. And the engines are not at all comparable. And so on, and so forth. |
22nd Oct 2020 7:20am |
Mid row folding
Go to 1m 15secs and it is shown, and how to release the seat for use is also shown Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
22nd Oct 2020 8:38am |
Maybe this is applicable? SSM 74999 - Rear HVAC panel appears not to function 19th August 2020 Click image to enlarge Click image to enlarge |
9th Feb 2021 11:59am |
Ehloo Member Since: 05 Jan 2021 Location: California Posts: 5 |
i have the opposite issue but similar. my 2nd row is not working at all. no air coming out of the vents at all. none of the buttons in the rear do anything. the power button doesn’t do anything, knobs do nothing. i have yet been able to get air to flow from the second vents. car is going into the dealer and worried it’s going to be a big job
13th Feb 2021 6:27am |
big thanks for posting this SB. the last option fixed my issue. i am really dumb founded the engineering and programming with the car. hitting max defrost locks my rear climate even after max defrost has been turned off. completely bad design
13th Feb 2021 6:54am |
