![]() | Home > Technical > Td5 110 Fuel Filler Pipe Part No. |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
I keep going around in circles trying to work out the correct part number for the rubber filler hose for my prefix 2A Td5 110.
The closest I have got seems to be WLH500070 but it is listed for 5A prefix onwards and i have some vague recollection about the filler necks being a different size on later models. Could anyone possible confirm please? Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6732
This is the info for the 90 where the tank inlet definitely changed size
https://www.defender2.net/forum/topic74328.html 110 info below: 110 non Hi-Cap and 130 PIPES 1. ESR4414 (XA159807 to 5A690323) - start of Td5 to mid 2005MY [superceded to WLH500070] 2. WLH500070 (5A690324 onwards) - mid 2005MY Td5 on and all Pumas So basically 1 pipe. WLH500070 110 Hi-Cap PIPES 1. WFH101710 (XA159807 to 5A690323) - start of Td5 to mid 2005MY [superceded to WLH500050] 2. WLH500050 (5A690324 onwards) - mid 2005MY Td5 on and all Pumas So basically 1 pipe. WLH500050 110/130 TANKS 1. WHK100050 (XA159807 to 8A760303) (all Td5s and early Puma) [superceded to LR013167] 2. LR013167 (8A760304 onwards) The tank change point doesn't match the filler hose change point so I don't think there's a tank inlet size change like for the 90, but I'm happy to be corrected. 1988 90 Td5 NAS soft top
2015 D90 XS SWLast edited by Martin on 20th Oct 2020 5:12pm. Edited 1 time in total |
Brilliant Martin,
Thanks for clarifying! Steve 02' 110 TD5 Double Cab Rebuild Thread |
| All times are GMT |
