Home > Off Topic > BMW E90 weird start [video] |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2233 |
20th Oct 2020 10:04am |
Liam Murphy Member Since: 29 Jul 2020 Location: South Wales Posts: 92 |
Thanks Hank! I'll take a look at those belts but I don't think it's the same problem.
Mine doesn't start on first push button start, it does squeal as mentioned in that thread, but its definitely not a chirp. It's more like a trapped pig on fire. It also seems to surge the power too. Occasionally it does start on first attempt but you can tell it only just caught. Always starts fine on the second attempt. I'm praying it's not the starter motor, is a nightmare to change on these. |
20th Oct 2020 10:27am |
Yeah I watched your video. Difficult to tell but I thought it sounded a bit rubbery? What engine is it? > 110 XS Double Cab
> Instagram @simonlanemind Last edited by hank on 20th Oct 2020 9:28pm. Edited 1 time in total |
20th Oct 2020 10:53am |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1286 |
It almost sounds like some sort of electrically driven servo motor. Is it an automatic box? Hard to tell from the video where the noise is coming from, but could it be some sort of gearbox interlock which locks the vehicle in Park until the ignition is switched on? Perhaps it has gone faulty and is only working when you press the start button the 1st time. Complete guess and based on zero knowledge of the vehicle !!
20th Oct 2020 5:05pm |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
kind of sounds like those electric parking brakes Roaming around 🇳🇴🇨ðŸ‡
20th Oct 2020 5:16pm |
Are you depressing the brake pedal on the first push? Roaming around 🇳🇴🇨ðŸ‡
20th Oct 2020 5:40pm |
Hi thanks for this! It's a manual gearbox on a 318d 2007 engine |
20th Oct 2020 7:29pm |
I tried to get another video with the bonnet open but guess what? It started first time. It's so difficult to capture! But once it starts on the first go, it starts first time every time until it sits for a while. It's a manual 318d 2007 3 series btw. Thanks for the help, will try taking another look tomorrow. |
20th Oct 2020 7:37pm |
Thanks! I'm depressing the clutch as this one is a manual. |
20th Oct 2020 7:38pm |
Oh well, bang goes my theory!!!
Haha! Thanks though, I appreciate it. Should have given more details on my car first...
20th Oct 2020 7:40pm |
edit: thought it might be exhaust actuator flap but the noise is different and also after the engine starts. Unless it sounds different form inside the car?
https://f30.bimmerpost.com/forums/showthread.php?t=705415 > 110 XS Double Cab > Instagram @simonlanemind |
20th Oct 2020 9:22pm |
