![]() | Home > Td5 > location of the heater windscreen timer relay on 2002 TD5 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6682 ![]() ![]() ![]() |
Does it do this with the engine running as well? The timer will only engage with the engine running and the oil pressure light off.
Ps: it’s behind the instrument pack
theheffman Member Since: 21 Mar 2019 Location: bath Posts: 60 ![]() ![]() ![]() |
thanks, thats what i was afraid of.
Yup i have read that it only works with engine running and correct oil temp. Sounds like i need to start replacing the relays ! |
Nothing to do with oil temperature. It’s oil pressure. Once the oil pressure switch opens (oil warning lamp off, i.e. engine running) then the timer will operate the relay.
Instrument pack removal is 4 screws ![]() ![]() ![]() |
looks like is need to get the screwdriver out then
![]() thanks for the guidance . |
