![]() | Home > Maintenance & Modifications > Soft A Bar Puma vs TD |
I'm looking to buy a Soft A Bar from a forum member. I'm sure it will be confirmed shortly, but his vehicle list implies he drives a Td5 whilst I have a Puma with AC nose. I've looked at some on line photos and the A Bar seems to be the same, so I'm wondering if just the brackets need changing? Does anyone know if this will fit my truck if I get AM brackets from Flatdog etc, or if the actual A Bar is different as well?
Thanks in advance. Keen to get an answer to Bev asap so he can continue the sale if need be. ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 149 ![]() ![]() ![]() |
This is a soft abar from a 2004. The brackets are different to the later ones so be careful. I had a local fabrication company make a new set for me as mine were too corroded. I hunted high and low online and you cant buy them any more.
Thanks Andy. I could do the same for the brackets, the question I shall more whether the A Bar itself is the same/different between Td5 and Puma AC. I can't see that it is and the brackets may be the answer. Monsieur Le Grenadier
If the TD5 also has A/C then the front end is exactly the same. I don't know for sure whether these A bars came in A/C and non-A/C flavours but I doubt it. If not however, it won't even matter if the TD5 doesn't have A/C. Darren
There are two different kinds of brackets (I think) but they should all fit any front end as the mounting points are all the same.
![]() ![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 877 ![]() ![]() ![]() |
Ive just removed my soft A bar from my TD5 air con....cant see why it wouldn't fit the Puma, the brackets are rubbish, if were to refit mine I would drill through the bumper and fix with a nut and bolt...
Force64 Member Since: 02 Jan 2014 Location: Gatwick Posts: 196 ![]() ![]() ![]() |
I have a non winch A bar taken off my 2005 td5 as it now has a winch on.
If interested pm me and I can send some photos. Andy Defender Td5 XS90 |
If it’s a genuine winch bumper it’s only two cuts to your a bar and it will fit. The cuts are all marked up on the a bar already too
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Thanking you all, I think I have my answer.
