![]() | Home > Maintenance & Modifications > Puma mega fuse replacement |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8407 ![]() ![]() ![]() |
I have taken the fuse out completely. Cheers
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
Do you know why it’s there anyway?
In cace short cct or over load to help prevent fire as the starter cables is only rated for shore term fault current before the cable
insulation becomes damage and expose the copper conductor with short cct or over load the copper conductor will heat up The only trouble with thermal protection devices i.e. mega fuse 400 to 500 amp have slow reaction time to cop with current in starting the engine Last edited by dorsetsmith on 15th Oct 2020 9:32am. Edited 2 times in total |
Yep well aware. Having never seen the need for it prior and my usage/maint I didnt see need for it so removed it from my 2010 vehicle in 2010. Cheers
James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop Last edited by jst on 15th Oct 2020 6:43am. Edited 1 time in total |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6709 ![]() ![]() ![]() |
No reason why you can't put the mega fuse in a fuse holder mounted to the side of the seat box, with suitable cable in and out.
e.g. https://cpc.farnell.com/littelfuse/0298100...dp/FF02698 You *could* remove the fuse (it didn't exist pre-Puma) however it's not a bad thing to have in place in case of a fault with the starter/alternator or wiring to them. LR wouldn't have spent money on it for no reason... ![]() ![]() ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17954 ![]() ![]() ![]() |
Just remember that you can easily turn your Defender into a fireball electrically long before the megafuse blows. You really don't need a large current for a blaze.
Methodical work, double check everything, correct cabling size and crimping, heat shrink. Works every time for me.
Oh you mean like this.... |
