Home > Td5 > Transfer box oil change?
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Hi, service time coming up soon, I currently run castrol syntrans 75w-90 in the transfer box, but it's quite whiney between 50/60mph, would changing to a different oil grade help reduce the noise a bit? Researching I have found that ep 80w90w as per diff oils can be used even though the book states 75w-90 for transfer box Confused
Just wondering if anybody on here as any experience with swapping oil types for the transfer and if they could offer any advice?
Thanks
Mike
Post #860989 11th Oct 2020 3:58pm
jst
Hi Mike, if its noisy something is not happy. Changing oil viscosity may mask it but it won't fix it.
Are you sure its the t box making the noise? Is it noisy under power, ciadting or on over run? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #861000 11th Oct 2020 5:53pm
Mike c
Its noisy under power, if you back off it stops, it's only got about 96000 on the clock otherwise great, the gearbox itself runs and changes lovely hence suspecting the transfer box as the noise generator. I have read a whiney transfer box is common though? I just wondered if the oil would make any difference.
Thanks
Mike
Post #861002 11th Oct 2020 6:01pm
PCM
After many forum posts I went with Motul gear 300 in transfer gear and diffs.
Drives like a new motor.
Post #861008 11th Oct 2020 6:26pm
jst
have you tried removing props one at a time to check its not diffs. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #861107 12th Oct 2020 10:56am
Mike c
No I haven't tried this, obviously its something that will need further investigation. If it was the diffs though, wouldn't it do it all the time, so not just under load? I have depressed the clutch at that noisy speed briefly and the whine stops instantly Question
Post #861122 12th Oct 2020 12:27pm
Mike c
Hi, replying to my own post here, but what transfer box oil do you use, 75w 90w as per book or ep 80w 90w?
Thanks
Mike
Post #861422 13th Oct 2020 6:49pm
miker
Personally I have a drum of cheap ep 80 90.
Seems to do the trick, Box whines, but it's done 230k and has run dry at least once in it's lifetime.
Post #861469 13th Oct 2020 9:53pm
ALIMIF
Have you had any problem since putting the Motul oil in, did it stop the whining
Post #865003 2nd Nov 2020 5:45pm
Mike c
Its weird, I went with the book 75w-90 for my 2004, yet my land rover indy who really knows his stuff and has been in the business for many years told me it's the wrong oil for the transfer box?
I pointed out that I ordered the oil as per book, but he said it will make it noisy, I think he has always stuck with the ep 80w90w for years for diffs and transfer box. There seems to be a mix of views on here. Confused
Post #865035 2nd Nov 2020 6:35pm
