![]() | Home > Puma (Tdci) > Puma swivel grease level |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8278 ![]() ![]() ![]() |
Just whack a load in, any cv grease works, buy it in cartridge grease gun style cases, its cheaper and easier to add. To check it with a tent peg it would have to hot enough to be in liquid form surely? Cheers
Thank you for your pm, sorry I bothered to try and help. Cheers
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
In my experience they only leak when one or both bearings are worn/wearing leaving a gap between the seal and cup, or when the cup gets damaged/scored.
Well worth checking the bearing preload is set properly using the shims as per the workshop manual. As for the grease, pointless measuring it as it's not in liquid form. When empty you use one sachet/tube of one shot grease. Maybe go for half a tube as it looks like you've lost a fair bit. Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
![]() Chris |
i wouldnt bother, you will get a PM telling you your wrong. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Why did he ask for advice then?
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1117 ![]() ![]() ![]() |
He is still asking for advice... Otherwise, would I have started this thread??
I won't comment on jst's. |
