Home > In Car Electronics > CB Antenna Location - On the A Bar?
Bluest
My antenna is currently on a gutter mount above the drivers door, and works great. But the mount is wobbly, dmaging the paint and i can't find a better one. So, I've been looking at moving it elsewhere that doesn't require any hole drilling.
What about the A Bar at the front (bit like the Aussies do)? Would it ruin the performance? It could go there very easily, and running the cable would be very simple. 2007 110 TDCi Station Wagon XS
Post #860274 7th Oct 2020 2:52pm
markb110
I have seen them on a metal A bar as there is a good earth.
However, when I used to marshal at events in the past, if anyone was running a wip style aerial that could be a danger to a member of the public, we asked that it be removed.
Off-road the aerial will wip left and right to the vehicle, so could hurt someone standing to the side.
The Aussie ‘style’ of aerials are solid.
I have mine mounted on the rear roof panel below the top of the roof (and cage), depending on the event I would either use a 4ft wip aerial or a 7inch rubber aerial which does not get hung up when green laning.
Www.4x4cb.com
PCM 1 Mount, I also added an additional wire to the chassis to improve the earth.
Good luck
Post #860278 7th Oct 2020 3:49pm
jst
i have tried various mounts over the years and in the end succumbed to the fact that drilling a hole was the only realistic way of body mounting one securely. i use one with a separate earth, reception/transmission has always been good.
https://www.thunderpole.co.uk/fixed-body-m...t-kit.html Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #860281 7th Oct 2020 4:06pm
Bluest
I have a 1.5m stainless steel whip at the minute and it does spring about all over the place. I could go for something a bit shorter and without a sprung base maybe. The PSM mount is not for me as I made a promise to myself not to put any more holes in the car. 2007 110 TDCi Station Wagon XS
Post #860288 7th Oct 2020 4:35pm
Bluest
There is no reason why a gutter mount coudn't work, but the two commonly available ones (have had both) have a couple of stupid design flaws which renders them insecure and/or unable to be used properly on a Defender. 2007 110 TDCi Station Wagon XS
Post #860290 7th Oct 2020 4:39pm
Presumably, you take the cable in through the rear door seal? If so, I have seen an aerial mounted on a bracket that picks up on the two bodyside bolts for the top hinge of the rear door. Just a piece of angle really, trimmed to fit around the hinge and with a hole in for the aerial mount. Darren
Post #860354 7th Oct 2020 9:00pm
This may be of interest?
https://www.ebay.co.uk/itm/One-Pair-X-Clam...Sw~epZgaj1
(Check sizes and different sellers for prices etc).
I have had a pair of these for a light bar and have never moved since fitting. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #860365 7th Oct 2020 9:24pm
Bluest
The cable goes out through an unused grommet in the bulkhead then up the snorkel. That’s why I was thinking it would be an easy relocate to the front. 2007 110 TDCi Station Wagon XS
Post #860372 7th Oct 2020 9:36pm
Bluest
Good shout, I like the look of those Thumbs Up 2007 110 TDCi Station Wagon XS
Post #860374 7th Oct 2020 9:38pm
👍🏻 There are different sizes available for different size round tube, very secure and good looking.
Stainless bolts could be better quality but aren’t really pricey so no complaint from me. Very Happy ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #860378 7th Oct 2020 9:52pm
Ah, no help at all then Laughing
What about a little bracket on one of the windscreen hinge blocks? Darren
Post #860380 7th Oct 2020 9:59pm
Bluest
I’d definitely consider that if there was something neat. 2007 110 TDCi Station Wagon XS
Post #860383 7th Oct 2020 10:11pm
Here you go, although it'd be relatively easy thing to make:
https://www.trekoverland.com/collections/l...rma-tf7220
 Darren
Post #860400 8th Oct 2020 6:05am
Only thing I can think of you’d have to be careful of with the windscreen block mount is clearance and flex. I expect that would clear it though so long as the Antenna spring isn’t gigantic. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #860481 8th Oct 2020 4:20pm
Devon-Rover
I've run an antenna on an A bar. After a while you don't notice it is there really. There is a little 1/4 wave placeholder there most of the time, Oddroad I use a 'Modulator' antenna as it has enough spring not to snapped by trees but not mobile enough like a orbitor to flail about and hit the bonnet.
On road I use a top loaded antenna, for best range I have a 4ft 'Firestick' which seems to perform well enough.
A mini DV mount means the cable is small enough to pass through to the front too. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #860490 8th Oct 2020 5:46pm
