Home > Tdi > Fuel starvation under max load |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2079 |
Knackered alternator bearing causing alternator to seize ?
Mo The Land Rover 90 - Many are called, few are chosen. |
5th Oct 2020 10:54pm |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 |
Not sure why that would cause mis fuel? Insta: @thebenjordan4x4
6th Oct 2020 6:47am |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 487 |
I know of a 300tdi that when a new fuel tank was put in it would randomly splutter and occasionally cut out, turned out there was a bit of paper in the fuel tank going over the pick up. Worth checking tank is clean 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
6th Oct 2020 6:50am |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 640 |
Not sure about the electrical issue but fuel starvation could be the fuel lift pump giving up or blocked.
6th Oct 2020 6:58am |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
breather vent in filler cap blocked, causing vacuum.? 'Volvo XC 70, taking the rough with the smooth’
6th Oct 2020 7:41pm |
Thanks, its crossed my mind to swap out the lift pump as its simple and cheap - and I did wonder about the breather being blocked maybe causing that.
Can anyone try and explain the link between the electrics flickering while the spluttering happens? Thats the bit thats baffling me and made me think it's electrical rather than fuel - the electrics killing the stop solenoid of course as a byproduct... Insta: @thebenjordan4x4 |
7th Oct 2020 7:04am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
Mo did try.
Take the aux belt off, whats the alt bearing like? Are feed and return pipes connect correct way around? I would suggest alt loading system as mo did, or fuel blockage, if alt is eliminated start looking at fuel and what you have changes Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
7th Oct 2020 7:59am |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 389 |
Possibilities
Alternator as stated Breather to fuel tank blocked with and/or weak lift pump Blocked fuel sedimentor (if it has one) Blocked fuel filter --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
8th Oct 2020 1:10am |
Did it do it before tank change? Cheers
8th Oct 2020 6:00pm |
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 |
Leave the fuel cap off, =try,, then run a live from battery to stop solnoid ,=try , my moneys on lift pump,,,,i did fit a new fuel sender once ,and it hit the bottom of the tank, i cut 5 mm off pick up pipe, , ]
8th Oct 2020 7:57pm |
Horneteer Member Since: 10 Feb 2015 Location: Cornwall Posts: 60 |
My money's on the lift pump
I had a 300 tdi disco with a delphi lift pump. There's a screw in the centre of the top cap, so you can take the cap off to clean the filter strainer that you don't know is there . I had similar symptoms when the strainer was blocked with goo. |
8th Oct 2020 9:37pm |
hes not been back, maybe its fixed.
if it wasnt there before fitting new parts, i think the filter is wrong or more likely the pickup is squished into the bottom of the tank. if fault was there and new parts were trying to resolve it then lift pump gets my vote. a good fix and upgrade is an electric one RRC lift pump, makes priming easier too. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
8th Oct 2020 9:47pm |
I've fitted an electric facet duralift to my 200 because of the poor quality across the aftermarket suppliers of mechanical lift pumps.
8th Oct 2020 10:13pm |
Is there a thread or details anywhere on this? 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
9th Oct 2020 8:51am |
