Home > Td5 > Power steering pump leak
Greeny
My TD5 has developed a leak as per the photos.
Not sure where it is coming from the power steering pump. Whats the best thing to do here? I can't specifically identify where it is leaking from, it is kind of all over. The leak is very slow.
Cheers Greeny.
 Instagram - @Land_Rover_Defender
Post #860268 7th Oct 2020 2:07pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
First try snugging that up with a wrench Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #860269 7th Oct 2020 2:14pm
Greeny
Already tightened up what I could see, was all fairly tight to be honest. Instagram - @Land_Rover_Defender
Post #860292 7th Oct 2020 4:41pm
Dunkrw1
2003 Defender 90 Td5 CSW Blenheim Silver
I had to replace mine looks line the same leek 😳
Post #867224 14th Nov 2020 7:50am
Greeny
Yes already thinking about replacing it. Tightening the bolts didn't work and neither did some stop leak.
So a new pump will be ordered! Instagram - @Land_Rover_Defender
Post #867233 14th Nov 2020 9:48am
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
There is an o-ring at the end of the metal feed pipe.
If this fails it lets fluid out via the threads.
It’s hard to see on the photos but this could be the issue. Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #867239 14th Nov 2020 9:59am
Greeny
Cheers,
It is really hard to tell where it is coming from, I have cleaned it multiple times and it returns wet all over the feed pipe, bolts etc. It is hard to trace it back to one spot.
Making me think that replacing the pump is maybe best... Instagram - @Land_Rover_Defender
Post #867241 14th Nov 2020 10:01am
dorsetsmith
QYX100280
O Ring
Post #867242 14th Nov 2020 10:04am
Greeny
Where does that O ring fit specifically? Instagram - @Land_Rover_Defender
Post #867243 14th Nov 2020 10:06am
dorsetsmith
at the end of the pipe and also o ring on the hex part that`s trended in to pump badly
But no part number for this o ring
IF this hex part is re moved a spring loaded plunger will fly out you have been worn
Post #867246 14th Nov 2020 10:07am
Greeny
For the money I will give it a go!
Thanks for help! Hopefully that sorts it. Instagram - @Land_Rover_Defender
Post #867251 14th Nov 2020 10:16am
