Home > Off Topic > New Work Shop build
Page 3 of 7 <1234567>
Stacey007
Bit more done... the levels are all over the place and this piece of concrete is much higher than anywhere else...
So we cut a channel in it and I've been chipping away...
We have marked out the are and levels, I have the wood on order to build a frame round it.
Today I hired a job on breaker as the one I was borrowing was not really up to it Smile to say its raining is an understatement... but I can have a shower afterwards... So Safety first Thumbs Up
Anyway I plodded on and its now all broken up, just need to move it but that can wait !!
Post #859557 3rd Oct 2020 1:22pm
Stacey007
The rain continues and the little lad is loving our new 'water feature'
Post #859573 3rd Oct 2020 2:37pm
mk1collector
Looks like you might want a good think about drainage while your at the digging stage! Ray
My build thread
Post #859591 3rd Oct 2020 4:29pm
Stacey007
We have a lot of soil in huge mounds on what was the garden which probably isn't helping...
Your right though, plan is to have a soakaway just up from where its pooling. Then also some aco drians on the solid part running into the existing drains.
Hopefully it will be better.
Post #859758 4th Oct 2020 2:53pm
Stacey007
today we started buildn the frame for concrete.
Oh and I moved another 2 tonnes of crush
Post #859759 4th Oct 2020 2:56pm
the gamekeeper
England 2007 Defender 110 Puma 2.4 DCPU Tonga Green
What is your ground make up if your planning to create a soak away?
Post #859771 4th Oct 2020 4:28pm
Stacey007
Hi Gamekeeper,
How do you mean, it just looks like grass / soil to me.....
Further up outside of our property is apparently a spring, this runs through our garden at an angle, plan is to use perforated pipe and have a channel from higher up in the garden to the soak away.
Then have separate additional aco drains in front of the new building and guttering to existing drains.
Post #859807 4th Oct 2020 7:13pm
JOW240725
I think what gamekeeper is getting at is soakaways dont work if ground heavy clay or water logged (high water table).
I'm sure your builders know what they're talking about though. I'd always much rather drain water to a ditch or off-site drainage if possible. James
Instagram @suffolk_rovers
Post #859815 4th Oct 2020 7:37pm
Stacey007
Builders....
Its me & me dad😃
However the digger guy has been working on this sort of stuff for 30 years or more so hopefully has an idea.
Your both right though now is the time to sort
Post #859832 4th Oct 2020 9:57pm
AJC
good work, i made a serious mess of our garden at weekend too!
Post #859925 5th Oct 2020 4:11pm
Stacey007
Not much update, but I have been busy...
I've had the concrete guy come round and look at job. He's checked the levels and I needed to break a bit more of existing concrete so the breaker hired again.
Then while we had the breaker we have temporarily fixed the water backing up.
Then today I've cut out a channel and broke the concrete up ready for a heavy duty aco drain.
This will also help with drainage as water does pool here.
Post #860976 11th Oct 2020 3:27pm
Stacey007
Little to report
but... Aco drain in near front of 'yard area' where the water used to pool anyway so good job done.
Framework up as Concrete guy specified, with lots of rebar and brace pieces.
So Need to get the concrete guy round to check all looks ok and then book in a day or two of dry weather...
Maybe doesn't look like much but only being able to work after work and part of weekends, its a job on Smile especially with the British weather at the moment.
I've been looking at drainage for the roof water and have an idea for that, then I need to start widening the path on the left as you look at the 'floor-plan' as this needs to have a retaining wall down one side.... That's going to be fun as the ground is solid,
Post #862581 20th Oct 2020 12:01pm
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Need to get a few tone of blinding down before you concrete Thumbs Up
Post #862601 20th Oct 2020 2:25pm
Stacey007
Well the weather had been so bad lately very little to report.
Its either too wet for concrete or too cold at the moment,and my job is in a queue behind others.
Anyway now I've finished work I've spent a few morning digging out wet solid clay / sandstone to make the path down the side wider ready for a retaining wall.
So I started here, and making it just over 1m wide
I'm now here... so about 3m more to do.
Then I need to work out what size RSJ's I need and have them made /cut to size.
Its going to be fun trying to sink these into the ground.
So I'm plodding on slowly.....
Post #874157 22nd Dec 2020 1:05pm
Stacey007
Big Big update, the garden and everywhere else still looks a state but...
Concrete poured on Friday, team arrived at 7am with the pump truck and concrete arrived at 7.30
I also hired a petrol poker which apparently works very well making it even better...
The guys pouring it one of them is coming back on Saturday to cut an expansion slot right across.
So one truck with 7.5 cubic meters and another with 6 cubic meters...
Pump truck
Poker in use
12m x 6m base done !!
So this then has a knock on affect as I then moved 76 concrete blocks from the front of the house to the back ready to build the base the garage is going to sit on top.
I've still loads of jobs but this feels like I'm heading forwards again. The area looks bigger than it did awaiting the concrete.. very odd but it does.. Will have to get them back to sort a ramp and other bits at a later date.
Then I put our hand prints under where a workbench will go before it set with the kids Smile and then put our initials on them
so lots still to do put happy this is done.
Post #880868 25th Jan 2021 9:45pm
