![]() | Home > Off Topic > UPVC Window advice, please |
| DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2065
Sounds like there is a need to fix the outside if rain is coming through into the inside.
| stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561
Just go to your local builder / diy merchants and ask for a couple tubes of white frame seal
And yes defo sort the outside first |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2459
For the outside I would clean out existing sealant, clean with upvc cleaner then wash down and dry. For deep gaps use an expanding foam. Short bursts as it expands like crazy and gets really messy inside and out. Note inside should be sealed with the beading or a quality acrylic sealant (as that can be painted etc) before using foam from outside, else it will expand inside and mess up decoration.Any foam that does get on the upvc frame can be wiped off and a short squirt of WD40 and a rub with a rag removes any residue ( yes finally a good use of wd40! ). Do this before it sets hard. On outside cut back dried foam so it is a few mm short of the face of the frame. Then use quality silicon sealant to fill the gap between frame and wall. Dow Corning 796 is a great silicon for this.
| Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736
Dow 796 UPVC silicone sealant would be fine (£6.28 from Screwfix).
Outside is a must as well as inside. However do not use silicone sealant if you need to paint over. If paint is needed use Acrylic. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
Many thanks, everyone, great advice and just what I was after!
I love this forum! |
Oh...and a mistake a lot of people make is to lick their finger before smoothing silicon or acrylic down. This adds bacteria to the mix and can cause mould. If using a finger or thumb have a small cup of water to add lubrication, not saliva . You can also buy silicon finishing tools. A little kit is only a couple of pounds on line and gives lots of finishing profiles. Just google silicon finishing tools. Again lube with water.
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986
Don’t use silicone it always eventually fails, peals off, and stops the ability to paint anywhere you have smeared it. This is the type of what I would use
https://www.screwfix.com/p/evo-stik-sticks..._container |
