Home > Maintenance & Modifications > Gywn Lewis trailing arms
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
In a world of double din fascias, and LED lights, things like this seems to be getting rarer.
I’m still a bit of a sucker for stuff like this, even though I don’t do much serious off-reading these days.
My trailing arm bushes had seen better days. So it was a good excuse to fit them.
The gywn Lewis ones are huge compare to the standard ones.
They went on easily, just the old axle end nuts took a bit of muscle to remove.
It’s the first time I’ve used non standard bushes, but these Super Pro bushes are softer than normal poly bushes, so I thought I’d give them a try.
It’s difficult to compare , these with genuine bushes, but new Super Pro bushes are better than the old worn out ones for sure.
It seems less harsh now over bigger bumps, so so far so good. 👍🏻
 2002 td5 90 county hardtop
Post #859029 30th Sep 2020 9:45pm
landy andy
Good kit from Gwyn, and I also use and like the super pro bushes. Keep the non Led and non bling post going Thumbs Up Thumbs Up
Post #859056 1st Oct 2020 7:56am
SteveG
2005 Defender 90 Td5 CSW Belize Green
Just to make this post more blingy 😉😉😉
Post #859063 1st Oct 2020 8:45am
LR90XS2011
looking good DEFENDER 90 TDCI XS,
Post #859064 1st Oct 2020 8:57am
jaygti
Yes it does look good indeed Steve.👍🏻 That’s proper old fashioned bling😉
I didn’t mention it in the first post, but these are faultless as far as construction and finishing are concerned, as are my gywn Lewis props.
Post #859066 1st Oct 2020 9:07am
jst
I ran a set of gywns cranked rear arms for 8 years, prior to fitting them the 90 used to mash std bushes, chassis end, 2" lift and dislocation, ran Superpro blue in them. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #859067 1st Oct 2020 9:10am
Mo Murphy
Not double din or led but still very shiny Jay ! 🤣
Steve, the chassis is looking pornographic !
50 Shades of Pennine Grey
Post #859080 1st Oct 2020 9:45am
jst
does this count as bling then?
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #859105 1st Oct 2020 11:26am
hank
Aussie chassis! > 110 XS Double Cab
Post #859110 1st Oct 2020 11:40am
jst
to be fair the photo was the only time this chassis was that way up (well completely).
the build after this spend ages upside down............... after the build! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #859116 1st Oct 2020 12:59pm
