![]() | Home > Maintenance & Modifications > Defender 90 Puma intermittent starting. |
rich585 Member Since: 30 Sep 2020 Location: dorset UK Posts: 18 ![]() ![]() |
Just tried a start and got the click of death. Whack the Dash. Started! Hmmm maybe it is the dash connector solder joints....
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
sounds like starter motor solenoid. Cheers
Except that whacking the dash appeared to clear the fault... will keep trying this to see if it's repeatable. If it is, then it's the dash soldering... |
I would start with the basics.
Is it not the starter solenoïde contacts? I don't have a Puma so don't know exactly how they are mounted. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6683 ![]() ![]() ![]() |
It's a solder issue on the instrument cluster (like your Ford - similar problem).
See https://www.defender2.net/forum/post814212.html#814212 ![]() ![]() |
