Home > Maintenance & Modifications > Cracked Axle Casing Advice Needed Please |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16871 |
Is it a similar crack to the one discussed in this thread ?
There is in principle no reason why it couldn't be welded, but how difficult it would be and the preparation required (including the decision about removal etc) would depend on the nature and position of the crack. Any chance on a photo or two? It would make it easier to provide advice. Swapping a casing, if you know what you're doing and have the toosl etc to had, maybe a couple of hours if everything undoes without too much difficulty. Allow a day if it's the first time you've done it. |
27th Sep 2020 12:39pm |
foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 357 |
many thanks for this. I'll get some photos. I don't think that thread applies to me. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
27th Sep 2020 1:07pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 601 |
Get a 300tdi disco front axle casing or axle. Exactly the same. Td5 use different pan hard rod mounting bracket, can be got around with new pan hard rod too but 300tdi disco is easiest swap.
27th Sep 2020 2:29pm |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1829 |
^^^^ Hope this isn't considered a thread hijack - but it might help Foxhound anyway.
Can you explain more on the difference between panhard brackets Td5 vs Tdi axle?? And how would I know what's on my car? The story is that at some point in the past, due to the first owners having a tendency to leave the car in the sea.... (maybe a slight exaggeration, but it was permanently hitched to a rescue boat at an island airport) the front axle was corroding away around the spring and radius arm mounts. It was replaced, and I think it might be a Td5 casing. Now, I have a Tdi casing which I'm about to get blasted and painted, and then I'll build it up with new parts for a swap. However I didn't know about the panhard rod differences... Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
27th Sep 2020 5:05pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2078 |
The earlier panhard rod is a forged one piece bar with a kick in it around the diff pan. The later rods are a straight welded tube assembly.
HTH Mo The Land Rover 90 - Many are called, few are chosen. |
27th Sep 2020 6:18pm |
Thanks Mo, that certainly does help me. I'm pretty sure I have the later/straight one at the moment so will need to get hold of a cranked one when I get to that stage. I wonder if there was any other reason behind changing the bracket on the newer axles, beyond not having manufacture cranked panhard rods?
Foxhound - sorry for the sidetracking. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
27th Sep 2020 6:48pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2547 |
Cost-driven decision I am sure. But the later ones do have a slightly heavier bush I think.
The change was for the 2002 model year, so early Td5s had the older setup. |
27th Sep 2020 7:22pm |
cee-b Member Since: 25 Jan 2018 Location: South West Posts: 114 |
I know that I'm bound to get a fair bit of stick for suggesting a 'bodge' but..... If it is a fine crack with a slow weep, I would be tempted to stop-drill it so it doesn't grow, clean it up thoroughly from the outside and then repair it with JB Weld. |
27th Sep 2020 7:32pm |
You'd knowingly drive with a cracked front axle case? Wow.
If it subsequently fails and you kill someone, you'd be ok with that? |
27th Sep 2020 7:41pm |
I think maybe the difference between our viewpoints is experience blackwolf.
I spent my working life as an Aviation Engineer. You'd be surprised how many aircraft you've flown in that had cracks in them that have been stop-drilled and repaired. Or even just stop-drilled and left unrepaired, depending on location. Obviously, it is a judgement call depending on severity but, if it is a small, fine crack in what is a very rugged piece of the vehicle with very few shear forces on it, why would it fail? |
27th Sep 2020 7:53pm |
Indeed we have different views, that much is clear. Furthermore, with respect, you have absolutely no idea what experience I have nor my background.
I can however categorically assure you that I would not knowingly drive a vehicle with a cracked axle case, nor, for that matter, operate nor allow to be operated an aeroplane with a crack in a component of equivalent importance to airworthiness as a front axle is to road-worthiness, and that is all I shall say on this matter. We will continue to have differing views, I am sure. |
27th Sep 2020 10:51pm |
Dear God, I've heard it all now ! Mo The Land Rover 90 - Many are called, few are chosen. |
28th Sep 2020 1:55am |
thanks all, my crack is weldable (my local LR expert has now been able to look at it) and he'll do that tomorrow but I've been offered a decent casing free which I'll collect and swap over in the next few weeks.
How does a casing crack? I've not heard of that happening before. I am wondering what the cause could be. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
28th Sep 2020 10:55am |
A latent defect or stress.
28th Sep 2020 12:37pm |
