![]() | Home > General & Technical (L663) > Parking brake operation device use |
umbertob Member Since: 21 Jun 2020 Location: Altadena, CA Posts: 133 ![]() ![]() |
Same here, the way the park brake hold is implemented is absolutely brilliant. No more lunging forward or backward an inch or two after hitting the P button, car stays planted in place until you hit the gas pedal, and it all happens so seamlessly. I can't even hear the squeal of the park brake engaging or the clunk of it disengaging - unless I have the window open. Only downside will be the inevitable wear and tear on the mechanism, but you're right: I don't see myself ever reaching for that lever except maybe in an emergency.
clarence_l663 Member Since: 25 Sep 2020 Location: California Posts: 3 ![]() ![]() |
Same. The push/pull operation is not intuitive (I always mixed up engaging and release the EPB). But then once I release the EPB will engage automatically when shift to Park, and disengage when shift to Drive, I haven’t touched the EPB once since. 2020 Defender P400 SE Eiger Grey
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3493 ![]() ![]() |
My Velar is 3 years old or will soon be and I’ve yet to touch the EPB, put the car in park and it’s applied put it in drive and it’s released.
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Be wary of constantly using 'P' only on the auto box - over time there is a risk of bending/damaging the parking pawl in the gearbox. Rgds.
Chris |
The car has to go into park, even in neutral and switched off it defaults to park. When park is selected the EPB is applied automatically.
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
EPB has automatically applied on every Range Rover I’ve own since 2005, none has had the hold function though which holds the car until you select P and the EPB is engaged. The EPB also seems to engage automatically if you switch of the engine but not if you are using the auto stop/start which utilises the hold until the engine stops then the red hand brake icon comes on until you drive away again. If you only press lightly on the foot brake the hold operates without activating the auto stop start. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
