Home > Off Topic > New Work Shop build
Page 1 of 7 1234567>
Stacey007
New Work Shop build
Well following my post on bricks others maybe interested to see my new garage / Workshop build.
After spending weeks going through quotes from bespoke oak garages, Steel framed ones and wooden ones I have come up with my choice and options.
I've gone for basically a shed, but thicker and a bit bigger. The way I looked at it, its a workshop / garage and for what I can get size wise this should do me nicely.
So it will be 6m wide with 2 double doors, and 12m long with windows at the back and side along with two pedestrian doors.
Luckily we have two garages, one attached to the house and another at the back , its the back garage I 'have' its detached from the house and is my 'space' it has served its purpose but as we all know, we need more room !!!
So the current set up...when we moved in 7 years ago..
I tried to make it 'look' better and added a carport for the trailer(s)
But you cannot really work on a car in it... not with all the other stuff we accumulate... I sorted it once...
So I was waiting to speak to planning about building a new one, but due to Covid everything shut down. Then out of the blue the planning website changed and it comes under permitted development and the size is governed by your plot... so the build starts. Thumbs Up
Anyone who has emptied a garage knows just how much stuff we keep.....what a job !!
Post #857684 23rd Sep 2020 5:53pm
Stacey007
So after emptying the old garage... Managed to find someone who wanted it...
so.....
gone....
So now I need to make the base, wider and much longer, the levels are all to pot with the current slam raising up towards the garden.
Post #857692 23rd Sep 2020 6:18pm
Co1
Settling in to watch this one! I do love a good workshop build.
Post #857698 23rd Sep 2020 6:24pm
Retroanaconda
Absolutely. Timber structure or masonry?
Post #857702 23rd Sep 2020 6:30pm
Stacey007
Wooden,
Basically a huge shed only thicker and a tad bigger 6m wide by 12m long....
first peal back cut in the garden...
Someone mentioned stumps.... I had the ones at the side removed with a stump grinder, but we had 3 at the back..... quite large !!! which we had to try and remove....
This gives you an idea of size, so removing 3 took quite a while !!!
very handy that the guy I chose to help me do the digging drives a Landrover !!!
Post #857708 23rd Sep 2020 6:40pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I hope the new workshop is tall enough for your forthcoming car lift...? Every home should have one!
Post #857711 23rd Sep 2020 6:46pm
Stacey007
^ it will not be.... due to planning I can only go up 4m.
With the span of the building the best we think we can get is around 800mm to 1000mm to jack up the car at one point in the garage. Using a stepped up joist / beam.
to be honest that's better than what I had by 100% so will make getting under it easier anyway Thumbs Up
Post #857716 23rd Sep 2020 6:54pm
sako243
Do a Si Rafferty and bolt the garage to the lift so when you need it the shed goes up with the lift and still keeps you dry. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #857719 23rd Sep 2020 6:59pm
Co1
Genius!!
Post #857747 23rd Sep 2020 8:00pm
Tomcat 106
2016 Defender 110 Puma 2.2 CSW Corris Grey
....got to love a workshop self build project Very Happy
Just sort of finished mine. All signed off....just a few internal jobs and I can move the toys back in Thumbs Up
Good luck! MY15.5 110XS CSW
1956 88" S1
2004 Tomcat 106 Comp safari
Post #857752 23rd Sep 2020 8:14pm
DSC-off
No lift... is there opportunity to dig a pit before the new concrete is laid?
Post #857753 23rd Sep 2020 8:22pm
Stacey007
I will get a small lift it just will not go up very high Smile
Did think about a pit but the extra time, effort to build that. I've enough on at the moment.
Post #857760 23rd Sep 2020 8:42pm
the gamekeeper
England 2007 Defender 110 Puma 2.4 DCPU Tonga Green
Is the side of the garage on the side of your boundary as it should be clear by 1M to fall under PD requirement?
Post #857765 23rd Sep 2020 8:56pm
Is that a thing?
Post #857806 24th Sep 2020 7:33am
sako243
Well not so much a shed but Si did make a carport to enclose his lift next to the shed at home. In everyday use his vehicles could be parked undercover and if he wanted to work on them the carport went up with it so even if it rained he could stay dry underneath. Ed
Post #857807 24th Sep 2020 7:38am
