![]() | Home > Technical > Internal hoop |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17857 ![]() ![]() ![]() |
The Safety Devices full cage has an internal hoop in that position, there's no reason it couldn't be installed on its own.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8322 ![]() ![]() ![]() |
cheers, I googled sd but couldn't give just the hoop, so thought it was probably someone else's! Cheers
I'm not saying the one you're thinking of is necessarily SD, but the SD one is the only one I know of that fits there.
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 921 ![]() ![]() |
Just remember internal cages are a common source of injuries. Unless you are strapped into the seat with a harness and wearing a crash helmet.
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
"behind the drivers seat in a 1100 station wagon."
Bet that has one hell of a turning circle, is it articulated? ![]() ![]() ![]() |
it is the one, just cant find it! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
yep, am, well aware thank you Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
http://blog.challenger4x4.com/search/label/Roll%20Cages
Like this one? |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 671 ![]() ![]() |
Hi James
The standalone internal hoop part no. Is RBL115 4SSS-B if you have no headlining and RBL033 4SSS-B with headlining. You change the 4 for a 5 if you want the diagonal strut brace. This can be connected at the top on both sides to an external cage with adapter brackets. This is the same hoop used on the 90’s with a bulkhead removal that was factory on my 50th and I had on the TD5 90 The full internal external 110 cage has a different internal hoop that I suspect has no individual part number. When I got my p38 parts from SD you could get anything that was in a kit individually even if it didn’t have a part number, but that was almost twenty years ago before they changed hands several times. 🙄 |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
I have a P&P internal hoop in my 110, it bolts through the roof to mate up with the external bits, but I see no reason why you couldn't use a couple of blank plates on the outside to mount it. It also bolts up the upper seatbelt fixings on the B pillars.
Having said that, I don't know how strong it would be on its own; if you rolled directly onto your roof, maybe OK (although it doesn't have a diagonal so would crush anyway) but if you were sliding along a road on your roof, there'd be no lateral support frontways or backwards (that comes from where it's bolted to the outside bit of the cage. Think you'd be better with a complete internal passenger cage. which I think SD and P&P do. Shout if you want any pics of mine James |
