Home > Tdi > Oil in Exhaust Manifold
Fatbaron
I'm finally fitting the new turbo along with a load of other jobs, I've whipped the inlet manifold off which I'll be giving a good clean.
There's obviously now oil in the exhaust manifold too, what would be the best way to get this cleaned out?
The manifold gasket was in 4 pieces when I took it off. Rolling Eyes
Post #855809 13th Sep 2020 2:51pm
Retroanaconda
Paraffin or some kind of solvent-based cleaner will bring it up nicely.
Post #855828 13th Sep 2020 4:28pm
Fatbaron
Cheers Retro, do I need to worry about getting solvent etc. down the intakes?
Post #855911 14th Sep 2020 7:47am
ibexman
I’ve used meths before it evaporates
Post #855927 14th Sep 2020 9:08am
shaggydog
Be worth doing the intercooler too as it will look the same on the inside and degrade its cooling ability.
I generally use Meths too then leave it on a radiator indoors to evaporate off Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #856001 14th Sep 2020 3:06pm
Retroanaconda
I’d use a rag for the head ports rather than spraying anything in there.
Post #856035 14th Sep 2020 6:07pm
Fatbaron
I've nicked the old one off my other engine, clean as a whistle. Cleaned out the ports as best I could with a rag dipped in degreaser.
Full size intercooler being put on along with the new turbo, silicone hoses, XL rad etc. I've been stockpiling parts for a year so while the gearbox is out and I've finally got time, I'm chucking it all on. Cool
Post #856045 14th Sep 2020 7:06pm
L110CDL
So at last you have a chance to put all of those bits on Red now Wink
Good you have time in between the work load Thumbs Up Clayton.
Keeper.
Post #856063 14th Sep 2020 8:52pm
Fatbaron
Yep, cheers Clayton. If you fancy a cuppa mate, feel free to pop round. I can show you what a doddle fitting a slick shift is now the gearbox is out. Thumbs Up
Post #856102 15th Sep 2020 4:43am
L110CDL
Thanks, will come round for a cuppa when i have 5 minutes Thumbs Up Clayton.
Keeper.
Post #856741 18th Sep 2020 9:48pm
